주요 콘텐츠로 건너뛰기
Kodak EasyShare CD82 Lens Assembly Replacement
필요한 것
  1. Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 1/3 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 2/3 Kodak EasyShare CD82 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 3/3
    • Remove the batteries and the memory card from the device.
    • Remove the two screws located at the bottom of the camera.
  2. Kodak EasyShare CD82 Lens Assembly Replacement: 2 단계, 이미지 1/3 Kodak EasyShare CD82 Lens Assembly Replacement: 2 단계, 이미지 2/3 Kodak EasyShare CD82 Lens Assembly Replacement: 2 단계, 이미지 3/3
    • Remove the two screws on the side of the device, to left of the camera lens.
    • Remove the two screws on side of the device, to the right of the camera lens.
    • Pry the casing apart at the seems, starting at the battery compartment.
  3. Kodak EasyShare CD82 Lens Assembly Replacement: 3 단계, 이미지 1/3 Kodak EasyShare CD82 Lens Assembly Replacement: 3 단계, 이미지 2/3 Kodak EasyShare CD82 Lens Assembly Replacement: 3 단계, 이미지 3/3
    • Remove the front casing from the mid-frame, first.
    • Continue to remove the back casing from the mid-frame.
    • Do not remove the LCD screen from the device once it becomes visible.
  4. Kodak EasyShare CD82 Lens Assembly Replacement: 4 단계, 이미지 1/3 Kodak EasyShare CD82 Lens Assembly Replacement: 4 단계, 이미지 2/3 Kodak EasyShare CD82 Lens Assembly Replacement: 4 단계, 이미지 3/3
    • Flip the LCD screen out of the holder from the top to reveal ribbon cable.
    • This camera had some obvious water damage..
    • Remove the three screws from the LCD holder
    • Dislodge the LCD screen holder from the circuit board connector.
  5. Kodak EasyShare CD82 Lens Assembly Replacement: 5 단계, 이미지 1/3 Kodak EasyShare CD82 Lens Assembly Replacement: 5 단계, 이미지 2/3 Kodak EasyShare CD82 Lens Assembly Replacement: 5 단계, 이미지 3/3
    • Disconnect the logic board from the frame on the right side of the device.
    • Remove the small ribbon cable, connecting the button board to the logic board, with small pair of tweezers or hemostat.
    • Remove the screw on the top right side of the device connecting the LCD screen holder to the midframe.
    • Move the black clip into the upward position to disconnect the cable.
    • You will now be able to remove the LCD screen and its holder from the device.
  6. Kodak EasyShare CD82 Lens Assembly Replacement: 6 단계, 이미지 1/3 Kodak EasyShare CD82 Lens Assembly Replacement: 6 단계, 이미지 2/3 Kodak EasyShare CD82 Lens Assembly Replacement: 6 단계, 이미지 3/3
    • Flip the black clips of the connectors into the opposite direction. Remove the lens and CCD cable.
    • Remove the two screws securing the lens to the midframe.
    • These are missing screws for the CCD sensor, lost in a previous dismantling.
    • Remove the single screw securing the lens to the mid-frame. The lens will now be loose.
    • Push the lens out of the frame in an angular direction, and remove.
  7. Kodak EasyShare CD82 Lens Assembly Replacement: 7 단계, 이미지 1/1
    • Insert the new lens the same way it was removed.
    • Clean and reassemble the camera.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
oldturkey03
회원 가입일: 09/29/10
782,402 평판
안내서 119개 작성하였습니다
Global Fixers Global Fixers 회원
Community
33 회원들
안내서 544개 작성하였습니다
댓글 한 개
When it says "Dislodge the LCD screen holder from the circuit board connector" does it mean that I can break that solder without desoldering and it's okay?
Sith Siri - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,670
