주요 콘텐츠로 건너뛰기
Kodak Easyshare C183 LCD Replacement
필요한 것
  1. Kodak Easyshare C183 LCD Replacement, LCD: 1 단계, 이미지 3개 중 1개 Kodak Easyshare C183 LCD Replacement, LCD: 1 단계, 이미지 3개 중 2개 Kodak Easyshare C183 LCD Replacement, LCD: 1 단계, 이미지 3개 중 3개
    • Remove the two screws from the right hand side
    • Remove the two screws from the left hand side
    • Remove the three screws from the bottom.
    • All the screws on this camera are the same size. No need to mark them by position.
  2. Kodak Easyshare C183 LCD Replacement: 2 단계, 이미지 3개 중 1개 Kodak Easyshare C183 LCD Replacement: 2 단계, 이미지 3개 중 2개 Kodak Easyshare C183 LCD Replacement: 2 단계, 이미지 3개 중 3개
    • Open the battery compartment and start carefully to separate the front and back half of the camera. On this camera the front half will come of first.
    • In the top left corner is one screw that will have to be removed. It holds the back cover to the body of the camera.
    • Once that screw is removed, the camera separates easy.
  3. Kodak Easyshare C183 LCD Replacement: 3 단계, 이미지 3개 중 1개 Kodak Easyshare C183 LCD Replacement: 3 단계, 이미지 3개 중 2개 Kodak Easyshare C183 LCD Replacement: 3 단계, 이미지 3개 중 3개
    • Fold the LCD from the top downward. DO NOT try to remove the LCD, it is still attached. Obviously this camera has had water damage.
    • Remove the Kapton tape from the top of the camera.
    • you will have to de-solder the battery frame on one point.
  4. Kodak Easyshare C183 LCD Replacement: 4 단계, 이미지 3개 중 1개 Kodak Easyshare C183 LCD Replacement: 4 단계, 이미지 3개 중 2개 Kodak Easyshare C183 LCD Replacement: 4 단계, 이미지 3개 중 3개
    • Remove the tape
    • Remove the single screw.
    • You can disconnect the ribbon cable, by carefully pulling on the end. I opted to leave it connected to minimize the risk of tearing the fragile cable. It is possible to just move the frame out of the way.
  5. Kodak Easyshare C183 LCD Replacement: 5 단계, 이미지 3개 중 1개 Kodak Easyshare C183 LCD Replacement: 5 단계, 이미지 3개 중 2개 Kodak Easyshare C183 LCD Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the LCD frame slightly up and fold the black clip gently to the back.
    • This will loosen the ribbon cable and lets your remove the LCD.
    • Insert the ribbon cable of the new LCD. there will be a solid white stripe on the cable. Insert the cable as shown, close the connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
837,092 평판
안내서 123개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 21
전체 시간: 2,623
