주요 콘텐츠로 건너뛰기
Kodak Easyshare C183 Lens Assembly Replacement
필요한 것
  1. Kodak Easyshare C183 Lens Assembly Replacement, Lens: 1 단계, 이미지 3개 중 1개 Kodak Easyshare C183 Lens Assembly Replacement, Lens: 1 단계, 이미지 3개 중 2개 Kodak Easyshare C183 Lens Assembly Replacement, Lens: 1 단계, 이미지 3개 중 3개
    • Remove the batteries, memory card and wrist strap, if so equipped.
    • Remove the three Phillips screws on the bottom.
    • Remove the two Phillips screws on the right hand side.
  2. Kodak Easyshare C183 Lens Assembly Replacement: 2 단계, 이미지 3개 중 1개 Kodak Easyshare C183 Lens Assembly Replacement: 2 단계, 이미지 3개 중 2개 Kodak Easyshare C183 Lens Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two screws on the left hand side.
    • Nicely enough, all the screws are the same size. No need to keep them separated.
    • Start splitting the case from the battery holder. You can use an opening tool or just your fingernails.
  3. Kodak Easyshare C183 Lens Assembly Replacement: 3 단계, 이미지 3개 중 1개 Kodak Easyshare C183 Lens Assembly Replacement: 3 단계, 이미지 3개 중 2개 Kodak Easyshare C183 Lens Assembly Replacement: 3 단계, 이미지 3개 중 3개
    • The camera's front half will come off first.
    • Remove the one screw on the top left of the camera. It this holds the back case on to the midframe.
    • Remove the back case.
  4. Kodak Easyshare C183 Lens Assembly Replacement: 4 단계, 이미지 3개 중 1개 Kodak Easyshare C183 Lens Assembly Replacement: 4 단계, 이미지 3개 중 2개 Kodak Easyshare C183 Lens Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Gently move the LCD out of the holder. DO NOT TRY TO REMOVE THE LCD. Just fold it over.
    • Remove the one screw on the top corner of the holder.
    • Remove the ribbon cable from its connector. It is just pushed in. there are not clips to move. Gently pull it straight down.
    • Remove the solder that connects the LCD holder to the top logic board.
  5. Kodak Easyshare C183 Lens Assembly Replacement: 5 단계, 이미지 3개 중 1개 Kodak Easyshare C183 Lens Assembly Replacement: 5 단계, 이미지 3개 중 2개 Kodak Easyshare C183 Lens Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • The LCD holding board and the switches are removed as one unit.
    • Open the clip on the LCD ribbon cable connector. Use your fingernails to gently pull it toward the top of the camera.
    • Remove the LCD.
  6. Kodak Easyshare C183 Lens Assembly Replacement: 6 단계, 이미지 3개 중 1개 Kodak Easyshare C183 Lens Assembly Replacement: 6 단계, 이미지 3개 중 2개 Kodak Easyshare C183 Lens Assembly Replacement: 6 단계, 이미지 3개 중 3개
    • Open the connectors for the CCD and the lens. Both use a clip that hold the cable is places. Move those gently into the opposite direction of the cables. this will free the cable.
    • Remove the two screws that hold the lens in place.
    • With the screws and the cables removed, use your fingers and push the lens upward and angled out of the midframe.
  7. Kodak Easyshare C183 Lens Assembly Replacement: 7 단계, 이미지 1개 중 1개
    • This is what your final result should look like. the lens is now free from the midframe and a new lens can be easily installed.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
oldturkey03
회원 가입일: 09/29/10
837,194 평판
안내서 123개를 작성함
3가이드 댓글
ممنون از اطلاعات تان
hamid kaker - 답글
خواهش میکنم. امیدوارم کمک کرده باشد.
oldturkey03 -
More I have this camera but I don't know what went wrong, so what went wrong, it is not on camera.
Mohd Ayaz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 21
전체 시간: 2,231
