이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn off camera by firmly pressing the power button that is located on the top of the camera near the mode selector dial.
Locate battery compartment on bottom of camera and slide open by applying pressure in the direction of the arrow.
Locate memory card slot and insert memory card by inserting the gold terminals first.
Apply pressure into you feel it lock into place.
Note: To remove a memory card, apply pressure down until you feel it click. Then it should pop up and you can just pull it up.
Turn on camera.
If you encounter a problem refer to your memory card, reference: Camera Memory Problems
다른 한 분이 해당 안내서를 완성하였습니다.
