주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kodak Easyshare C813 Shutter Button Replacement
필요한 것
    1. Kodak Easyshare C813 Shutter Button Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
      댓글 쓰기
    2. Kodak Easyshare C813 Shutter Button Replacement: 2 단계, 이미지 3개 중 1개 Kodak Easyshare C813 Shutter Button Replacement: 2 단계, 이미지 3개 중 2개 Kodak Easyshare C813 Shutter Button Replacement: 2 단계, 이미지 3개 중 3개
      • Press thumb firmly on battery door and slide it in the direction of the arrow.
      • Lift thumb allowing the door to swing open.
      댓글 쓰기
    1. Kodak Easyshare C813 Shutter Button Replacement, Back Cover: 3 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      Anti-Static Wrist Strap
      $7.95
      댓글 쓰기
    2. Kodak Easyshare C813 Shutter Button Replacement: 4 단계, 이미지 1개 중 1개
      • Turn the camera off by firmly pressing the power button located on top of the camera.
      댓글 쓰기
    3. Kodak Easyshare C813 Shutter Button Replacement: 5 단계, 이미지 3개 중 1개 Kodak Easyshare C813 Shutter Button Replacement: 5 단계, 이미지 3개 중 2개 Kodak Easyshare C813 Shutter Button Replacement: 5 단계, 이미지 3개 중 3개
      • Locate the 7 screws holding the back cover on.
      • Three screws are located on the bottom of the camera.
      • Two screws are located on the side shown in the photograph.
      • Two final screws are located on the opposite side shown in the photograph.
      댓글 쓰기
    4. Kodak Easyshare C813 Shutter Button Replacement: 6 단계, 이미지 3개 중 1개 Kodak Easyshare C813 Shutter Button Replacement: 6 단계, 이미지 3개 중 2개 Kodak Easyshare C813 Shutter Button Replacement: 6 단계, 이미지 3개 중 3개
      • Remove all 7 screws:
      • Hold the camera firmly with one hand so that you can still see a screw.
      • Place the Philips 00(Found here)screwdriver into the screw.
      • Turn the screwdriver to the left until it is free.
      • Repeat for the remaining screws.
      댓글 쓰기
    5. Kodak Easyshare C813 Shutter Button Replacement: 7 단계, 이미지 3개 중 1개 Kodak Easyshare C813 Shutter Button Replacement: 7 단계, 이미지 3개 중 2개 Kodak Easyshare C813 Shutter Button Replacement: 7 단계, 이미지 3개 중 3개
      • Use plastic opening tools to slightly open the side of the case.
      • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
      • The first two are near the words "3X Optical Zoom".
      • The third is near the shutter button.
      댓글 쓰기
    6. Kodak Easyshare C813 Shutter Button Replacement: 8 단계, 이미지 3개 중 1개 Kodak Easyshare C813 Shutter Button Replacement: 8 단계, 이미지 3개 중 2개 Kodak Easyshare C813 Shutter Button Replacement: 8 단계, 이미지 3개 중 3개
      • Gently pull apart the back cover from the rest of the camera.
      • Make sure there are no more screws or tabs keeping the cover on.
      • Use the plastic opening tool to separate any sides still closely connected.
      댓글 쓰기
    1. Kodak Easyshare C813 Shutter Button Replacement, Front Cover: 9 단계, 이미지 2개 중 1개 Kodak Easyshare C813 Shutter Button Replacement, Front Cover: 9 단계, 이미지 2개 중 2개
      • Open the battery door.
      댓글 쓰기
    2. Kodak Easyshare C813 Shutter Button Replacement: 10 단계, 이미지 3개 중 1개 Kodak Easyshare C813 Shutter Button Replacement: 10 단계, 이미지 3개 중 2개 Kodak Easyshare C813 Shutter Button Replacement: 10 단계, 이미지 3개 중 3개
      • Use the plastic opening tool to lift the casing around the shutter button.
      • Gently remove the front cover from the device.
      댓글 쓰기
    3. Kodak Easyshare C813 Shutter Button Replacement: 11 단계, 이미지 1개 중 1개
      • Do not touch the terminals shown in the photo. These link to the capacitor which could shock you if not discharged.
      • To discharge the capacitor follow this guide.
      댓글 쓰기
    1. Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: 12 단계, 이미지 2개 중 1개 Kodak Easyshare C813 Shutter Button Replacement, Shutter Button: 12 단계, 이미지 2개 중 2개
      • The shutter button is held on to the front cover by three screws
      • Hold the shutter button in place
      • Use a Philips 00 screwdriver to remove the screws.
      • Careful that the power and flash button do not fall off
      댓글 쓰기
    2. Kodak Easyshare C813 Shutter Button Replacement: 13 단계, 이미지 3개 중 1개 Kodak Easyshare C813 Shutter Button Replacement: 13 단계, 이미지 3개 중 2개 Kodak Easyshare C813 Shutter Button Replacement: 13 단계, 이미지 3개 중 3개
      • Keep the shutter button in place while removing the circular metal plate
      • Remove the shutter button by allowing it to fall into your hand
      댓글 쓰기
    3. Kodak Easyshare C813 Shutter Button Replacement: 14 단계, 이미지 3개 중 1개 Kodak Easyshare C813 Shutter Button Replacement: 14 단계, 이미지 3개 중 2개 Kodak Easyshare C813 Shutter Button Replacement: 14 단계, 이미지 3개 중 3개
      • Hold down the shutter button portion of the selector dial
      • Press down the red tabs and slowly relieve pressure on the shutter button
      • Press down on the center red stick
      • Careful not to lose the spring
      • Tool shown is Found here
      댓글 쓰기
    4. Kodak Easyshare C813 Shutter Button Replacement: 15 단계, 이미지 1개 중 1개
      • If cleaning, remove dirt from button
      • When putting back together, the button should be be oriented so that the green automatic mode points towards the power button.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Susan Marano
회원 가입일: 04/15/10
342 평판
안내서 7개를 작성함
Cal Poly, Team 24-22, Regan Spring 2010 Cal Poly, Team 24-22, Regan Spring 2010 회원
CPSU-REGAN-S10S24G22
4 회원들
안내서 32개를 작성함
1가이드 댓글
does anybody know how the pins works on the surface mounted shutter switch button on the PCB? this would be very helpful thanks!
random - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 46
전체 시간: 8,527
