소개
Is your tablet not accepting charge, won't show things on screen, or you don't have audio? If you have tried changing the battery, screen, and audio jack and still have these problems, that means you need to change your mother board. This guide will require soldering so refer to this guide.
필요한 것
Use the Phillips #0 Screwdriver to remove four 5mm screws from sides of the device.
거의 끝나갑니다!
결론
