주요 콘텐츠로 건너뛰기
Kurio Touch 4S Screen Replacement
필요한 것
  1. Kurio Touch 4S Screen Replacement, Screen: 1 단계, 이미지 1/1
    • Make sure to open the back cover easily using the plastic opening tool
  2. Kurio Touch 4S Screen Replacement: 2 단계, 이미지 1/3 Kurio Touch 4S Screen Replacement: 2 단계, 이미지 2/3 Kurio Touch 4S Screen Replacement: 2 단계, 이미지 3/3
    • Remove back cover by prying away from the Kurio.
    • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  3. Kurio Touch 4S Screen Replacement: 3 단계, 이미지 1/2 Kurio Touch 4S Screen Replacement: 3 단계, 이미지 2/2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Philips#1 Screwdriver.
  4. Kurio Touch 4S Screen Replacement: 4 단계, 이미지 1/1
    • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
    • All these screws are identical so don't worry if you get them out of order.
  5. Kurio Touch 4S Screen Replacement: 5 단계, 이미지 1/1
    • Remove the plastic cover that is covering the camera area.
  6. Kurio Touch 4S Screen Replacement: 6 단계, 이미지 1/1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Screen Replacement: 7 단계, 이미지 1/1
    • Use Phillips # 1 screw to open the 4 screws on the motherboard.
    • Open the screws gently and do not apply too much force as you could damage the motherboard.
  8. Kurio Touch 4S Screen Replacement: 8 단계, 이미지 1/1
    • Use the plastic opener to remove the battery.
  9. Kurio Touch 4S Screen Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the black tape that is attached to the motherboard.
  10. Kurio Touch 4S Screen Replacement: 10 단계, 이미지 1/2 Kurio Touch 4S Screen Replacement: 10 단계, 이미지 2/2
    • Detach all the wire that are connected to the motherboard.
    • Also remove the camera module and other components that are attached to the motherboard.
    • For more information on soldering Click here
  11. Kurio Touch 4S Screen Replacement: 11 단계, 이미지 1/1
    • Remove the motherboard with the help of plastic opener.
    • Detach the power plug before you remove the motherboard.
  12. Kurio Touch 4S Screen Replacement: 12 단계, 이미지 1/1
    • Use the Plastic opener to remove the screen.
    • Do not apply too much pressure as the front cover could be damaged.
  13. Kurio Touch 4S Screen Replacement: 13 단계, 이미지 1/1
    • Use the soldering tool to remove the wire that is attached to the screen & the motherboard.
  14. Kurio Touch 4S Screen Replacement: 14 단계, 이미지 1/1
    • Use tweezers to remove the screen from your Kurio Toich 4S.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Ali
회원 가입일: 01/21/15
184 평판
안내서 1개 작성함
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 회원
USFT-BROWN-W15S6G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 11
전체 시간: 1,380
