주요 콘텐츠로 건너뛰기
Kurio Touch 4S Speaker Replacement
필요한 것
  1. Kurio Touch 4S Speaker  Replacement, Speakers: 1 단계, 이미지 1/1
    • Make sure to open the back cover easily using the plastic opening tool.
  2. Kurio Touch 4S Speaker  Replacement: 2 단계, 이미지 1/3 Kurio Touch 4S Speaker  Replacement: 2 단계, 이미지 2/3 Kurio Touch 4S Speaker  Replacement: 2 단계, 이미지 3/3
    • Remove back cover by prying away from the device.
    • The easiest place to remove the cover is from the bottom and top; try to open it from the right and left sides.
    • Open it gently. Do not open it with too much pressure, so that the plastic back cover do not break.
  3. Kurio Touch 4S Speaker  Replacement: 3 단계, 이미지 1/2 Kurio Touch 4S Speaker  Replacement: 3 단계, 이미지 2/2
    • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Phillips #1 Screwdriver
    • After you remove your four 5mm Philips screws, use your plastic opening tool to help you open the plastic cover of your device.
  4. Kurio Touch 4S Speaker  Replacement: 4 단계, 이미지 1/1
  5. Kurio Touch 4S Speaker  Replacement: 5 단계, 이미지 1/1
    • Gently remove the plastic cover that is covering the camera.
  6. Kurio Touch 4S Speaker  Replacement: 6 단계, 이미지 1/1
    • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  7. Kurio Touch 4S Speaker  Replacement: 7 단계, 이미지 1/1
    • Use the soldering tool to detach the speaker wires.
    • For more information on how to solder the wires Click here
  8. Kurio Touch 4S Speaker  Replacement: 8 단계, 이미지 1/1
    • Press the speaker in the manner shown so that it comes out of its slot.
    • Be sure not to apply too much force or you can break the back cover.
  9. Kurio Touch 4S Speaker  Replacement: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the Tweezers to remove the speaker from its place.
    • Remove the speaker gently.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Moin Khan
회원 가입일: 01/21/15
234 평판
안내서 2개 작성하였습니다
USF Tampa, Team 6-5, Brown Winter 2015 USF Tampa, Team 6-5, Brown Winter 2015 회원
USFT-BROWN-W15S6G5
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 170
