주요 콘텐츠로 건너뛰기
Kyocera Hydro Life Charging Port Replacement
필요한 것
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: 1 단계, 이미지 1/2 Kyocera Hydro Life Charging Port Replacement, Charging Port: 1 단계, 이미지 2/2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: 2 단계, 이미지 1/3 Kyocera Hydro Life Charging Port Replacement: 2 단계, 이미지 2/3 Kyocera Hydro Life Charging Port Replacement: 2 단계, 이미지 3/3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: 3 단계, 이미지 1/1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: 4 단계, 이미지 1/3 Kyocera Hydro Life Charging Port Replacement: 4 단계, 이미지 2/3 Kyocera Hydro Life Charging Port Replacement: 4 단계, 이미지 3/3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: 5 단계, 이미지 1/3 Kyocera Hydro Life Charging Port Replacement: 5 단계, 이미지 2/3 Kyocera Hydro Life Charging Port Replacement: 5 단계, 이미지 3/3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: 6 단계, 이미지 1/2 Kyocera Hydro Life Charging Port Replacement: 6 단계, 이미지 2/2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: 7 단계, 이미지 1/1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: 8 단계, 이미지 1/1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: 9 단계, 이미지 1/1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: 10 단계, 이미지 1/1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
결론
Rebecca Lamb
회원 가입일: 09/21/18
327 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 984
