주요 콘텐츠로 건너뛰기
LG Front Load Washing Machine Pressure Sensor Replacement
필요한 것
  1. LG Front Load Washing Machine Pressure Sensor Replacement, Safety Precautions: 1 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Pressure Sensor Replacement, Safety Precautions: 1 단계, 이미지 2개 중 2개
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. LG Front Load Washing Machine Pressure Sensor Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Pressure Sensor Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Pressure Sensor Replacement, Unfasten the top panel: 2 단계, 이미지 3개 중 3개
    • Remove the screw(s) securing the top panel brackets to the back panel.
    • You don't need to remove the screws securing the brackets to the top panel.
  3. LG Front Load Washing Machine Pressure Sensor Replacement, Remove the top panel: 3 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Pressure Sensor Replacement, Remove the top panel: 3 단계, 이미지 2개 중 2개
    • Slide the top panel towards the rear of the device to disconnect its clips.
  4. LG Front Load Washing Machine Pressure Sensor Replacement: 4 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Pressure Sensor Replacement: 4 단계, 이미지 2개 중 2개
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. LG Front Load Washing Machine Pressure Sensor Replacement, Disconnect the pressure sensor: 5 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Pressure Sensor Replacement, Disconnect the pressure sensor: 5 단계, 이미지 2개 중 2개
    • Depending on your device, your pressure sensor might have a wire harness. If so, disconnect each wire on the harness.
    • Disconnect the connector from the pressure sensor.
    • Always grip cables by their connectors and not the wires themselves.
  6. LG Front Load Washing Machine Pressure Sensor Replacement: 6 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Pressure Sensor Replacement: 6 단계, 이미지 2개 중 2개
    • Disconnect the hose from the pressure sensor.
  7. LG Front Load Washing Machine Pressure Sensor Replacement, Unfasten the pressure sensor: 7 단계, 이미지 1개 중 1개
    • Remove the screw(s) securing the pressure sensor.
  8. LG Front Load Washing Machine Pressure Sensor Replacement, Remove the pressure sensor: 8 단계, 이미지 3개 중 1개 LG Front Load Washing Machine Pressure Sensor Replacement, Remove the pressure sensor: 8 단계, 이미지 3개 중 2개 LG Front Load Washing Machine Pressure Sensor Replacement, Remove the pressure sensor: 8 단계, 이미지 3개 중 3개
    • Unclip the pressure sensor from the chassis or other components.
  9. LG Front Load Washing Machine Pressure Sensor Replacement: 9 단계, 이미지 2개 중 1개 LG Front Load Washing Machine Pressure Sensor Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the pressure sensor away chassis and remove it.
결론
Repair didn’t go as planned? Ask our Answers community for help.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Bill Gilbert
회원 가입일: 06/30/22
38,528 평판
안내서 261개를 작성함
iFixit iFixit 회원
Staff
123 회원들
안내서 23,784개를 작성함
4가이드 댓글
Would this sensor also be responsible for an oe error. Drain line is clear and pump removes most of the water. The machine then continues to cycle through spin and drain with very little water coming out. When I remove the emergency drain line, it only has a couple cups of water in it.
Lg tromm front load washer.
Fred Becker - 답글
I am having the same problem and I think that is my issue but am not sure.
John Hughes -
Hi Fred (and John), sorry for the long wait! Yes, that sensor could be responsible, but the tube is often plugged. The machine tries to pump itself out because the sensor is still getting a full signal from trapped air because of a clog in the tube that can act like a check valve. Sometimes, this pressure will bleed off over time, and the machine will stop trying to run a perennial drain cycle. Take a look at this part of the LG washing machine troubleshooting sheet. Even though it is for "no water," the same system is involved.
Bill Gilbert -
I just wanted to say I have been battling my LG front loading washer for the better part of a week and couldn’t get that pesky OE code to go away. I replaced the drain pump motor and checked for clogs in all the hoses except for the hose to that water pressure sensor. This advice was an absolute godsend, thank you so much. I was getting very close to looking at a new machine. After opening it back up again and taking out that hose it turns out that was what the issue ended up being. Now my washing machine runs like new! thanks again!
maxim pariset - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 185
전체 시간: 3,480
