소개
If your tablet isn't working properly, you may need to replace the motherboard. This guide will show you how to replace the motherboard.
필요한 것
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
거의 끝나갑니다!
결론
다른 8명이 해당 안내서를 완성하였습니다.
