주요 콘텐츠로 건너뛰기
LG G Pad 8.3 Volume Control Buttons Replacement
필요한 것
  1. LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: 1 단계, 이미지 1/2 LG G Pad 8.3 Volume Control Buttons Replacement, Back Panel: 1 단계, 이미지 2/2
    • With the tablet face down, pull the SD card slot cover out.
    • Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
  2. LG G Pad 8.3 Volume Control Buttons Replacement: 2 단계, 이미지 1/3 LG G Pad 8.3 Volume Control Buttons Replacement: 2 단계, 이미지 2/3 LG G Pad 8.3 Volume Control Buttons Replacement: 2 단계, 이미지 3/3
    • Insert a plastic opening tool in the small crevasse between the screen and the back panel.
    • Pry the screen away from the back panel.
    • Repeat this on each edge of the device.
    • We found it helpful to leave multiple plastic opening tools wedged in the crevasse to prevent it from closing.
    • This requires heavy force. The back of the device is attached with an adhesive. If the back panel is too hard to remove, use the iOpener.
  3. LG G Pad 8.3 Volume Control Buttons Replacement: 3 단계, 이미지 1/2 LG G Pad 8.3 Volume Control Buttons Replacement: 3 단계, 이미지 2/2
    • After using the plastic opening tools, pry the device open with your hands.
    • Remove the back panel from the screen.
  4. LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: 4 단계, 이미지 1/2 LG G Pad 8.3 Volume Control Buttons Replacement, Volume Control Buttons: 4 단계, 이미지 2/2
    • With the screen facing towards you and the top of the tablet towards your left, locate the volume buttons on the left side.
    • Using a spudger or your hands, remove the volume control buttons, which are attached with adhesive.
결론
Mario Salguero
회원 가입일: 09/14/15
781 평판
안내서 6개 작성하였습니다
CSU Fullerton, Team 1-6, Bruce Fall 2015 CSU Fullerton, Team 1-6, Bruce Fall 2015 회원
CSUF-BRUCE-F15S1G6
4 회원들
안내서 14개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,072
