주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG G Watch R Motherboard Replacement
필요한 것
  1. LG G Watch R Motherboard Replacement, Back Case: 1 단계, 이미지 2개 중 1개 LG G Watch R Motherboard Replacement, Back Case: 1 단계, 이미지 2개 중 2개
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 1개 LG G Watch R Motherboard Replacement, Motherboard: 4 단계, 이미지 2개 중 2개
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Motherboard Replacement: 5 단계, 이미지 2개 중 1개 LG G Watch R Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Westley Courchene
회원 가입일: 01/13/15
3,410 평판
안내서 14개를 작성함
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 회원
USFT-REMMELL-F15S1G1
5 회원들
안내서 14개를 작성함
3가이드 댓글
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - 답글 공유
Where do I buy a replacement motherboard from??
Brandon Reznik - 답글 공유
Did you ever find anywhere to order a replacement motherboard?
Robert Dye - 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 24
지난 30일: 88
전체 시간: 3,860
