주요 콘텐츠로 건너뛰기
LG G5 Battery Replacement
필요한 것
  1. LG G5 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 LG G5 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 LG G5 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: 2 단계, 이미지 2개 중 1개 LG G5 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
결론
다른 22명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Sam Goldheart
회원 가입일: 10/18/12
471,717 평판
안내서 538개를 작성함
iFixit iFixit 회원
Staff
118 회원들
안내서 19,533개를 작성함
댓글 4개
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - 답글
Was machen wenn Akku Snap In ab ist?
Ra Ku - 답글
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - 답글
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 70
전체 시간: 16,250
