주요 콘텐츠로 건너뛰기
LG G8 ThinQ Front Cameras Replacement
필요한 것
  1. LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: 1 단계, 이미지 1/3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: 1 단계, 이미지 2/3 LG G8 ThinQ Front Cameras Replacement, SIM Card Tray: 1 단계, 이미지 3/3
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Front Cameras Replacement, Back Panel: 2 단계, 이미지 1/3 LG G8 ThinQ Front Cameras Replacement, Back Panel: 2 단계, 이미지 2/3 LG G8 ThinQ Front Cameras Replacement, Back Panel: 2 단계, 이미지 3/3
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Front Cameras Replacement, Midframe: 3 단계, 이미지 1/3 LG G8 ThinQ Front Cameras Replacement, Midframe: 3 단계, 이미지 2/3 LG G8 ThinQ Front Cameras Replacement, Midframe: 3 단계, 이미지 3/3
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Front Cameras Replacement, Front Cameras: 4 단계, 이미지 1/2 LG G8 ThinQ Front Cameras Replacement, Front Cameras: 4 단계, 이미지 2/2
    • Using an opening tool, carefully disconnect the ribbon cables from both cameras.
  5. LG G8 ThinQ Front Cameras Replacement: 5 단계, 이미지 1/3 LG G8 ThinQ Front Cameras Replacement: 5 단계, 이미지 2/3 LG G8 ThinQ Front Cameras Replacement: 5 단계, 이미지 3/3
    • Using an opening tool, carefully pry up and remove both cameras from the phone casing.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Josh Cress
회원 가입일: 09/17/21
458 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 13
전체 시간: 430
