주요 콘텐츠로 건너뛰기
LG K30 Charging Port Replacement
필요한 것
  1. LG K30 Charging Port Replacement, Battery: 1 단계, 이미지 2개 중 1개 LG K30 Charging Port Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. LG K30 Charging Port Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. LG K30 Charging Port Replacement: 3 단계, 이미지 1개 중 1개
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. LG K30 Charging Port Replacement: 4 단계, 이미지 1개 중 1개
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. LG K30 Charging Port Replacement: 5 단계, 이미지 2개 중 1개 LG K30 Charging Port Replacement: 5 단계, 이미지 2개 중 2개
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. LG K30 Charging Port Replacement, Motherboard: 6 단계, 이미지 1개 중 1개
    • Use a spudger to carefully disconnect the front camera connector.
    • Use a spudger to disconnect the display cable connector.
  7. LG K30 Charging Port Replacement: 7 단계, 이미지 2개 중 1개 LG K30 Charging Port Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the motherboard assembly from the display assembly with the a spudger or hand.
  8. LG K30 Charging Port Replacement, Charging Port: 8 단계, 이미지 3개 중 1개 LG K30 Charging Port Replacement, Charging Port: 8 단계, 이미지 3개 중 2개 LG K30 Charging Port Replacement, Charging Port: 8 단계, 이미지 3개 중 3개
    • For a guide on how to solder and unsolder components; please refer to: How To Solder and Desolder Connections
    • Peel back gold plastic protective film on motherboard to reveal 4 solder points which need to be desoldered with the desoldering wick.
    • Use extreme caution: soldering iron can become extremely hot and cause burns.
  9. LG K30 Charging Port Replacement: 9 단계, 이미지 2개 중 1개 LG K30 Charging Port Replacement: 9 단계, 이미지 2개 중 2개
    • Flip the motherboard over to the backside and use soldering iron to melt the solder on the charging port terminals; use the desoldering wick to remove the solder.
결론
작성자
3다른 기여자 명과 함께
Alisha Lee
회원 가입일: 09/19/19
277 평판
안내서 3개를 작성함
댓글 한 개
Is the K30 the same inside as the K40?
Daisey Flowerr - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 2,317
