주요 콘텐츠로 건너뛰기
LG Optimus F60 Charging Port Replacement
필요한 것
  1. LG Optimus F60 Charging Port Replacement, Battery: 1 단계, 이미지 1/3 LG Optimus F60 Charging Port Replacement, Battery: 1 단계, 이미지 2/3 LG Optimus F60 Charging Port Replacement, Battery: 1 단계, 이미지 3/3
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Charging Port Replacement: 2 단계, 이미지 1/3 LG Optimus F60 Charging Port Replacement: 2 단계, 이미지 2/3 LG Optimus F60 Charging Port Replacement: 2 단계, 이미지 3/3
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Charging Port Replacement, Motherboard: 3 단계, 이미지 1/3 LG Optimus F60 Charging Port Replacement, Motherboard: 3 단계, 이미지 2/3 LG Optimus F60 Charging Port Replacement, Motherboard: 3 단계, 이미지 3/3
    • Use the Phillips #000 Screwdriver to remove the eight 4mm screws.
  4. LG Optimus F60 Charging Port Replacement: 4 단계, 이미지 1/2 LG Optimus F60 Charging Port Replacement: 4 단계, 이미지 2/2
    • Insert the iFixit opening tool in the indentation.
    • Pry the plastic using the opening tool to remove the lower back panel.
    • Remove the lower back panel from the device.
  5. LG Optimus F60 Charging Port Replacement: 5 단계, 이미지 1/3 LG Optimus F60 Charging Port Replacement: 5 단계, 이미지 2/3 LG Optimus F60 Charging Port Replacement: 5 단계, 이미지 3/3
    • Insert the iFixit opening tool starting under the charging port.
    • Continue to pry at the edges until loose enough to remove.
  6. LG Optimus F60 Charging Port Replacement: 6 단계, 이미지 1/3 LG Optimus F60 Charging Port Replacement: 6 단계, 이미지 2/3 LG Optimus F60 Charging Port Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Find the digitizer connector in the lower left hand corner of the device.
    • Use the tweezers to gently lift up and remove the connector.
  7. LG Optimus F60 Charging Port Replacement: 7 단계, 이미지 1/3 LG Optimus F60 Charging Port Replacement: 7 단계, 이미지 2/3 LG Optimus F60 Charging Port Replacement: 7 단계, 이미지 3/3
    • Gently pry the motherboard from the digitizer starting from under the charging port.
    • Remove and replace the motherboard.
  8. LG Optimus F60 Charging Port Replacement, Charging Port: 8 단계, 이미지 1/2 LG Optimus F60 Charging Port Replacement, Charging Port: 8 단계, 이미지 2/2
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mohammad Mohammad
회원 가입일: 03/25/19
451 평판
안내서 3개 작성하였습니다
IUPUI, Team S2-G5, Henning Spring 2019 IUPUI, Team S2-G5, Henning Spring 2019 회원
IUPUI-HENNING-S19S2G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 347
