주요 콘텐츠로 건너뛰기
LG Stylo 2 Charger Port Replacement
필요한 것
  1. LG Stylo 2 Charger Port Replacement, Battery: 1 단계, 이미지 1/3 LG Stylo 2 Charger Port Replacement, Battery: 1 단계, 이미지 2/3 LG Stylo 2 Charger Port Replacement, Battery: 1 단계, 이미지 3/3
    • First you need to remove the back case of the phone.
    • Place the phone face down.
    • Using the plastic opening tool, insert into the initial gap shown.
    • Slowly guide the tool around the case until the case comes off with ease.
  2. LG Stylo 2 Charger Port Replacement: 2 단계, 이미지 1/3 LG Stylo 2 Charger Port Replacement: 2 단계, 이미지 2/3 LG Stylo 2 Charger Port Replacement: 2 단계, 이미지 3/3
    • Place the back case to the side.
    • Use your finger or the opening tool to remove battery.
    • Remove the battery carefully to not damage the phone or the battery.
  3. LG Stylo 2 Charger Port Replacement, Rear Camera: 3 단계, 이미지 1/3 LG Stylo 2 Charger Port Replacement, Rear Camera: 3 단계, 이미지 2/3 LG Stylo 2 Charger Port Replacement, Rear Camera: 3 단계, 이미지 3/3
    • Remove the eleven 4mm Phillips #00 screws.
    • Place screws in safe location.
    • Use Plastic opener tool to remove inner case.
    • Gently remove inner case.
  4. LG Stylo 2 Charger Port Replacement: 4 단계, 이미지 1/3 LG Stylo 2 Charger Port Replacement: 4 단계, 이미지 2/3 LG Stylo 2 Charger Port Replacement: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use your finger or the opener to flip the flex cable shown in red box.
    • Use the precision tweezers to remove camera carefully.
  5. LG Stylo 2 Charger Port Replacement, Motherboard: 5 단계, 이미지 1/3 LG Stylo 2 Charger Port Replacement, Motherboard: 5 단계, 이미지 2/3 LG Stylo 2 Charger Port Replacement, Motherboard: 5 단계, 이미지 3/3
    • Gently flip the cables(shown in red boxes) using the opener tool.
    • Gently remove the motherboard itself.
    • Place motherboard on a soft surface to not damage it.
  6. LG Stylo 2 Charger Port Replacement, Charger Port: 6 단계, 이미지 1/3 LG Stylo 2 Charger Port Replacement, Charger Port: 6 단계, 이미지 2/3 LG Stylo 2 Charger Port Replacement, Charger Port: 6 단계, 이미지 3/3
    • Place motherboard on safe surface for Soldering Iron use.
    • Desolder the four connections
    • For more information on how to solder and desolder connections, please visit this guide.
    • Use Iron till the port is able to be removed.
    • Remove the port carefully and place on safe surface.
결론
Devon Barber
회원 가입일: 02/13/18
994 평판
안내서 5개 작성하였습니다
USF Tampa, Team S11-G1, Cheng Spring 2018 USF Tampa, Team S11-G1, Cheng Spring 2018 회원
USFT-CHENG-S18S11G1
4 회원들
안내서 10개 작성하였습니다
댓글 2개
The instructions on desoldering the port should not be followed in this guide, as you can clearly see in the pictures they damaged the motherboard. There are more than 4 connections that need to be desoldered. The four connections shown are only anchor points, and there’s several pads (i believe six, aside from the four anchor points) joined to the port that actually transmit the signal. If you do not desolder these points before removing the port, you WILL damage the motherboard significantly and it will require fairly complicated repair, or the replacement of the motherboard entirely, which is the most expensive component of the phone and holds all of the user information. Awful guide.
Clayton Reeser - 답글
I concur that mother board doesnt look good.. Then soldering the new one in.. The heat heat from that cant be good to an already damaged motherboard.. In my opinion get a phone where you can wireless charge it.. Try avoid using the port.. But anyways but if this does do it i’d just go buy me another decent phone.. It is what it is lol..
matthew02727 -
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 28
전체 시간: 5,839
