소개
Use this guide to replace the secondary rear-facing camera of your LG V20.
필요한 것
Insert a spudger or your fingernail under the battery at the small recess on the lower edge.
Be careful not to deform or puncture the battery.
Pry up and remove the battery.
Remove the sixteen 4mm Phillips #00 screws attaching the back cover to the motherboard.
Use an iOpener to loosen the adhesive beneath the secondary rear facing camera.
다른 한 분이 해당 안내서를 완성하였습니다.
