소개
The phone battery may be old, the CPU may be overloaded, the battery is no longer holding charge, and/or the device operating temperature is too hot. Try closing out unused apps, maintaining a safe operating temperature, and enabling power saver mode.
Before using this guide, make sure to review the LG V50 ThinQ troubleshooting page to ensure there are no other options to save your battery.
If the battery needs to be replaced, this guide will help you replace the battery for your LG V50 ThinQ android phone. Make sure the device is powered off before replacing the battery.
필요한 것
Flip the phone over, so that the back of the phone is facing you.
Using an opening pick, pry open the back cover of the phone by moving the opening pick along all sides to reveal the internal components.
다른 3명이 해당 안내서를 완성하였습니다.
