주요 콘텐츠로 건너뛰기
LG V50 ThinQ Screen Replacement
필요한 것
  1. LG V50 ThinQ Screen Replacement, Screen: 1 단계, 이미지 1/3 LG V50 ThinQ Screen Replacement, Screen: 1 단계, 이미지 2/3 LG V50 ThinQ Screen Replacement, Screen: 1 단계, 이미지 3/3
    • Flip the phone over, making sure that the back of the phone is facing up.
    • With an opening pick, run the tool along the edge of the back cover of the phone and carefully pry it open.
  2. LG V50 ThinQ Screen Replacement: 2 단계, 이미지 1/2 LG V50 ThinQ Screen Replacement: 2 단계, 이미지 2/2
    • With the device facing down, remove all 12 1mm Phillips #000 screws.
    • Keep in mind that the screws must be reused at the end of the guide to put the phone back together.
  3. LG V50 ThinQ Screen Replacement: 3 단계, 이미지 1/3 LG V50 ThinQ Screen Replacement: 3 단계, 이미지 2/3 LG V50 ThinQ Screen Replacement: 3 단계, 이미지 3/3
    • Remove the two brackets covering the internal components.
  4. LG V50 ThinQ Screen Replacement: 4 단계, 이미지 1/2 LG V50 ThinQ Screen Replacement: 4 단계, 이미지 2/2
    • Remove the battery connection from its connector port, located above the battery.
    • Similarly, remove the screen connection from its connector port, found on the left side of the back of the device.
  5. LG V50 ThinQ Screen Replacement: 5 단계, 이미지 1/1
    • With an opening pick (or a similar tool that isn't sharp), run the tool along the edge between the screen and the base of the phone.
    • After the screen is removed from the device, use a 1mm double-sided adhesive along the edges of the phone.
    • Carefully put the replacement screen into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Carlos Rivera
회원 가입일: 11/03/23
121 평판
안내서 1개 작성함
UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 UMass Dartmouth, Team 2-3, Gulbrandsen Fall 2023 회원
UMASSD-GULBRANDSEN-F23S2G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 35
전체 시간: 232
