주요 콘텐츠로 건너뛰기
LG Volt LS740 Charging Port Replacement
필요한 것
  1. LG Volt LS740 Charging Port Replacement, Power off and Unplug Phone: 1 단계, 이미지 1/2 LG Volt LS740 Charging Port Replacement, Power off and Unplug Phone: 1 단계, 이미지 2/2
    • Always power off and unplug your devices before servicing them.
  2. LG Volt LS740 Charging Port Replacement, Remove Rear Cover: 2 단계, 이미지 1/1
    • There is a pry tab you can use your fingernail or a pry tool to remove the rear cover.
  3. LG Volt LS740 Charging Port Replacement, Remove Battery & Sim Card: 3 단계, 이미지 1/2 LG Volt LS740 Charging Port Replacement, Remove Battery & Sim Card: 3 단계, 이미지 2/2
    • Note the location of the screws to remove the inner rear panel.
  4. LG Volt LS740 Charging Port Replacement, Remove Inner Rear Cover: 4 단계, 이미지 1/2 LG Volt LS740 Charging Port Replacement, Remove Inner Rear Cover: 4 단계, 이미지 2/2
    • Remove the 11 screws on the inside rear cover using your Phillips screw driver.
    • See photo from "Remove Battery" step for location of screws.
    • Use your pry tool and carefully work your way around the inside rear cover to undo the snaps and remove it.
  5. LG Volt LS740 Charging Port Replacement, Remove Charing Port / Daughter Board: 5 단계, 이미지 1/1
    • Disconnect the 3 cables and two screws before attempting to remove the charging port circuitry.
    • Beware the adhesive on the back!
결론
다른 2명이 해당 안내서를 완성하였습니다.
SMcC21985
회원 가입일: 11/10/15
1,253 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 365
