주요 콘텐츠로 건너뛰기
LG X Power Charging Port Replacement
필요한 것
  1. LG X Power Charging Port Replacement, LG X Power Disassembly: 1 단계, 이미지 1/2 LG X Power Charging Port Replacement, LG X Power Disassembly: 1 단계, 이미지 2/2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Charging Port Replacement: 2 단계, 이미지 1/2 LG X Power Charging Port Replacement: 2 단계, 이미지 2/2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Charging Port Replacement: 3 단계, 이미지 1/2 LG X Power Charging Port Replacement: 3 단계, 이미지 2/2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Charging Port Replacement, Charging Port: 4 단계, 이미지 1/3 LG X Power Charging Port Replacement, Charging Port: 4 단계, 이미지 2/3 LG X Power Charging Port Replacement, Charging Port: 4 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Charging Port Replacement: 5 단계, 이미지 1/1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Charging Port Replacement: 6 단계, 이미지 1/1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Charging Port Replacement: 7 단계, 이미지 1/1
    • Desolder the MicroUSB charging port from the motherboard.
    • If you need help soldering, follow this guide.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Chad Sears
회원 가입일: 02/14/18
1,170 평판
안내서 5개 작성하였습니다
USF Tampa, Team S3-G6, Nance Spring 2018 USF Tampa, Team S3-G6, Nance Spring 2018 회원
USFT-NANCE-S18S3G6
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
Where can i get the charging port part? There are so many different usb female ports.
Wayne Newell - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 15
전체 시간: 5,921
