주요 콘텐츠로 건너뛰기
LG X Power Screen Replacement
필요한 것
  1. LG X Power Screen Replacement, LG X Power Disassembly: 1 단계, 이미지 1/2 LG X Power Screen Replacement, LG X Power Disassembly: 1 단계, 이미지 2/2
    • Insert a plastic opening tool above the AUX jack and slide it around the perimeter to pop the back cover off.
  2. LG X Power Screen Replacement: 2 단계, 이미지 1/2 LG X Power Screen Replacement: 2 단계, 이미지 2/2
    • Remove the twelve 2.5mm Phillips #0 screws from the back of the phone.
  3. LG X Power Screen Replacement: 3 단계, 이미지 1/2 LG X Power Screen Replacement: 3 단계, 이미지 2/2
    • Insert a plastic opening tool underneath the mid-frame and pry upwards until you hear a click.
    • With the plastic opening tool still underneath the mid-frame, work your way around the perimeter until it's free from the smartphone.
  4. LG X Power Screen Replacement, Battery: 4 단계, 이미지 1/3 LG X Power Screen Replacement, Battery: 4 단계, 이미지 2/3 LG X Power Screen Replacement, Battery: 4 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the front and rear cameras from the motherboard.
    • Pull the cameras out to remove them.
  5. LG X Power Screen Replacement: 5 단계, 이미지 1/1
    • Use the flat end of a spudger to disconnect the battery from the motherboard.
    • You will not be removing anything, just disconnecting.
  6. LG X Power Screen Replacement: 6 단계, 이미지 1/1
    • Insert a plastic opening tool underneath the motherboard and pry upwards to remove it.
  7. LG X Power Screen Replacement: 7 단계, 이미지 1/2 LG X Power Screen Replacement: 7 단계, 이미지 2/2
    • Use a spudger and plastic opening tool to carefully pry up the battery.
    • There is a strong adhesive on the back of the battery that will make it difficult to remove.
  8. LG X Power Screen Replacement, Screen: 8 단계, 이미지 1/2 LG X Power Screen Replacement, Screen: 8 단계, 이미지 2/2
    • Carefully peal off the glued vibration motor by using the plastic opening tool.
  9. LG X Power Screen Replacement: 9 단계, 이미지 1/2 LG X Power Screen Replacement: 9 단계, 이미지 2/2
    • Using the plastic opening tool, pry off the ear speaker.
결론
다른 16명이 해당 안내서를 완성하였습니다.
khaled Albannaw
회원 가입일: 02/14/18
374 평판
안내서 1개 작성함
USF Tampa, Team S3-G6, Nance Spring 2018 USF Tampa, Team S3-G6, Nance Spring 2018 회원
USFT-NANCE-S18S3G6
3 회원들
안내서 12개 작성하였습니다
댓글 7개
If you are just replacing the screen, this is wrong. This would help if you are replacing with a “screen in frame”
asears - 답글
What is the right way for just the screen?
Kodi Butscha -
Please add “with frame” in title. Also need to make sure all contacts are present on the frame of the new screen, transfer them over if not.
rian_bay - 답글
Is the x power screen the same size ( or same screen altogether) as the x power 3 screen? If not what screen would I be looking for?
Jonathan - 답글
Where’s the part where you actually remove the screen and add in the new one?
The last step seems to be prying off the ear speaker.
Could you please fix this guide when you get the chance? I might replace the screen on my LG Power X [K210]. Thanks.
A Mix Of Geek Stuff - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 34
전체 시간: 8,272
