주요 콘텐츠로 건너뛰기
Laser X 88016 LED Lights Repair
필요한 것
  1. Laser X 88016 LED Lights Repair, Laser X 88016 LED Lights Repair: 1 단계, 이미지 1/2 Laser X 88016 LED Lights Repair, Laser X 88016 LED Lights Repair: 1 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the one 9.6 mm screw from the bottom of the laser gun and pull off the battery cover.
    • Phillips #0 will be used for all subsequent screw extractions throughout this guide.
    • Remove the three AAA batteries.
  2. Laser X 88016 LED Lights Repair: 2 단계, 이미지 1/3 Laser X 88016 LED Lights Repair: 2 단계, 이미지 2/3 Laser X 88016 LED Lights Repair: 2 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the six 9.6 mm screws located on the back of the receiver to expose the circuit board.
  3. Laser X 88016 LED Lights Repair: 3 단계, 이미지 1/2 Laser X 88016 LED Lights Repair: 3 단계, 이미지 2/2
    • Remove the 9.6mm screw fixing the circuit board to the receivers front cover using the Phillips #0 screwdriver.
  4. Laser X 88016 LED Lights Repair: 4 단계, 이미지 1/1
    • Identify the LED wires on the circuit board and determine where the wires have become disconnected or shorted.
  5. Laser X 88016 LED Lights Repair: 5 단계, 이미지 1/3 Laser X 88016 LED Lights Repair: 5 단계, 이미지 2/3 Laser X 88016 LED Lights Repair: 5 단계, 이미지 3/3
    • The LED wires are labeled TX and TG.
    • Use a helping hand to hold circuit board steady for soldering.
    • Solder the disconnected wire to the circuit board (in this case, the white wire to the node labeled TX.
    • Caution: Never touch the element or tip of the soldering iron. They are very hot (about 400°C) and will burn. Always return the soldering iron to its stand when not in use.
  6. Laser X 88016 LED Lights Repair: 6 단계, 이미지 1/3 Laser X 88016 LED Lights Repair: 6 단계, 이미지 2/3 Laser X 88016 LED Lights Repair: 6 단계, 이미지 3/3
    • Reattach the circuit board to the receiver's front plate.
    • Put the batteries back in the laser gun and test for LED lights functionality.
    • If a specific LED light still does not function, verify the solder is not making a connection with the adjacent nodes.
결론
James Lewis
회원 가입일: 09/15/20
133 평판
안내서 1개 작성함
University of Memphis, Team S2-G9, Willis Fall 2020 University of Memphis, Team S2-G9, Willis Fall 2020 회원
UM-WILLIS-F20S2G9
1 회원
안내서 1개 작성하였습니다
댓글 한 개
Hi, Do you know the PN for SW1? that turn on and off the unit?
Thanks
Alon S. - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 39
전체 시간: 2,659
