주요 콘텐츠로 건너뛰기
Lasko CD08200 Disassembly
필요한 것
  1. Lasko CD08200 Disassembly, Lasko CD08200 Disassembly: 1 단계, 이미지 1/2 Lasko CD08200 Disassembly, Lasko CD08200 Disassembly: 1 단계, 이미지 2/2
    • Turn over the device and place it on its head.
    • Remove the four 14mm screws holding the bottom using a TR15 screwdriver.
  2. Lasko CD08200 Disassembly: 2 단계, 이미지 1/1
    • Remove both 14mm screws from the power cord casing using a Phillips #2 screwdriver.
    • Remove the power cord casing from the device case.
  3. Lasko CD08200 Disassembly: 3 단계, 이미지 1/3 Lasko CD08200 Disassembly: 3 단계, 이미지 2/3 Lasko CD08200 Disassembly: 3 단계, 이미지 3/3
    • Cut the sticker on the right side of the device using a Jimmy.
    • Unscrew the four 14mm screws with a Phillips #2 bit on the back of the device.
    • If your screwdriver cannot reach the screw, you can use the metal spudger.
    • Remove the back casing from the device.
  4. Lasko CD08200 Disassembly: 4 단계, 이미지 1/3 Lasko CD08200 Disassembly: 4 단계, 이미지 2/3 Lasko CD08200 Disassembly: 4 단계, 이미지 3/3
    • Remove the four 14mm screws housing the fan using the Phillips #2 screwdriver.
    • Remove the top of the fan housing with the fan attached and place it on the table.
결론
Artur Komissarov
회원 가입일: 01/14/20
382 평판
안내서 2개 작성하였습니다
York University, Team S1-G1, Woodhouse Winter 2020 York University, Team S1-G1, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G1
3 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 14
전체 시간: 266
