주요 콘텐츠로 건너뛰기
LeapFrog LeapPad2 Explorer Speaker Replacement
필요한 것
  1. LeapFrog LeapPad2 Explorer Speaker Replacement, Battery: 1 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Before disassembling your LeapPad, ensure your device is shut off.
    • Push outward on the plastic side panels to remove and reveal battery.
    • The panels should detach fully from the main device.
  2. LeapFrog LeapPad2 Explorer Speaker Replacement: 2 단계, 이미지 3개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement: 2 단계, 이미지 3개 중 2개 LeapFrog LeapPad2 Explorer Speaker Replacement: 2 단계, 이미지 3개 중 3개
    • Push down from the positive end of the battery towards the negative end to pry the battery up out of its dispenser.
    • Remove all four AA alkaline batteries from the device.
  3. LeapFrog LeapPad2 Explorer Speaker Replacement, Back Cover: 3 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement, Back Cover: 3 단계, 이미지 2개 중 2개
    • This step will void your device warranty.
    • Remove the following screws securing the back cover to the main device:
    • Two 10.0 mm Phillips screws
    • Four 4.0 mm Phillips screws
    • Three 3.0 mm Phillips screws
  4. LeapFrog LeapPad2 Explorer Speaker Replacement: 4 단계, 이미지 3개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement: 4 단계, 이미지 3개 중 2개 LeapFrog LeapPad2 Explorer Speaker Replacement: 4 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool into the seam between the front and rear covers to detach the back cover from the rest of the device.
    • Move the plastic opening tool around the perimeter of the LeapPad2.
    • Lift up and remove the rear case from the tablet.
    • A butter knife can help when prying the device.
  5. LeapFrog LeapPad2 Explorer Speaker Replacement, Front Cover: 5 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement, Front Cover: 5 단계, 이미지 2개 중 2개
    • Remove the following screws securing the front cover to the main device:
    • Three 6.0 mm Phillips screws
    • Three 7.0 mm Phillips screws
    • Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
    • The white plastic component holding the speaker must be removed to reach the third 7.0 mm Phillips screw. Refer to Step 2.
  6. LeapFrog LeapPad2 Explorer Speaker Replacement: 6 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the white plastic piece to expose the third 7.0 mm Phillips screw mentioned.
  7. LeapFrog LeapPad2 Explorer Speaker Replacement: 7 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • When unscrewing the game cartridge screws, you will find a loose black plastic component underneath the game cartridge.
    • Use tweezers to remove the piece.
    • In case the piece falls out unexpectedly, refer to this step to make sure you put this piece back in place during the reassembly of your device.
  8. LeapFrog LeapPad2 Explorer Speaker Replacement: 8 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Desolder the through hole-components in power plugs on both sides of the device where the batteries were once connected.
    • Do not refer to the pictures in this step for correct soldering and de-soldering techniques. They are solely for illustration purposes.
    • For proper soldering and desoldering techniques reference 연결부 납땜 및 납제거 방법.
    • Soldering requires the iron to be at hot temperatures and can cause burns. Wear safety glasses as needed.
    • Be extremely careful with the cables in this step as they could melt, burn, or break.
  9. LeapFrog LeapPad2 Explorer Speaker Replacement: 9 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Pry the power cables from the device using your fingers or tweezers.
    • Now you should be able to lift up the front cover, leaving you with the motherboard and screen.
  10. LeapFrog LeapPad2 Explorer Speaker Replacement, Speaker: 10 단계, 이미지 2개 중 1개 LeapFrog LeapPad2 Explorer Speaker Replacement, Speaker: 10 단계, 이미지 2개 중 2개
    • Finally, locate and desolder the remaining connections from speaker wires on the circuit.
    • Once finished desoldering, flip to the other side of the circuit board to remove the wires.
    • Reference How To Solder and Desolder Connections to learn how to solder.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Nupur Garg
회원 가입일: 04/12/14
867 평판
안내서 7개를 작성함
Cal Poly, Team 8-10, Regan Spring 2014 Cal Poly, Team 8-10, Regan Spring 2014 회원
CPSU-REGAN-S14S8G10
4 회원들
안내서 16개를 작성함
1가이드 댓글
What type of speaker do I need to use to replace it with?
Bond Dye - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 21
전체 시간: 4,566
