주요 콘텐츠로 건너뛰기
Lego Dimensions Starter Pack Motherboard Replacement
필요한 것
  1. Lego Dimensions Starter Pack Motherboard Replacement, Top Cover Parts: 1 단계, 이미지 1/2 Lego Dimensions Starter Pack Motherboard Replacement, Top Cover Parts: 1 단계, 이미지 2/2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack Motherboard Replacement: 2 단계, 이미지 1/1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack Motherboard Replacement: 3 단계, 이미지 1/1
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack Motherboard Replacement: 4 단계, 이미지 1/1
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack Motherboard Replacement: 5 단계, 이미지 1/1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack Motherboard Replacement, USB Cable: 6 단계, 이미지 1/1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
  7. Lego Dimensions Starter Pack Motherboard Replacement, LED Chip: 7 단계, 이미지 1/1
    • Pull the black connector of the ribbon away from the LED chip, keeping the connector parallel to the board.
    • Disconnect the connector on the other LED chip as well, if replacing both LED chips or the motherboard
  8. Lego Dimensions Starter Pack Motherboard Replacement: 8 단계, 이미지 1/1
    • Pull the ribbon away from the black connector of the LED chips.
    • Disconnect the ribbon from the other LED chip as well, if replacing both LED chips or the motherboard.
  9. Lego Dimensions Starter Pack Motherboard Replacement: 9 단계, 이미지 1/1
    • Lift up both LED chips. As you are lifting, pull towards the motherboard to release it from the toy pad cover.
  10. Lego Dimensions Starter Pack Motherboard Replacement: 10 단계, 이미지 1/1
    • Lift up the motherboard, and remove the motherboard and LED chips from the toy pad.
  11. Lego Dimensions Starter Pack Motherboard Replacement: 11 단계, 이미지 1/1
    • Flip the motherboard and LED chips over.
    • Desolder the LED chip from the motherboard.
    • Desolder both LED chips, if replacing both LED chips or the motherboard
    • Separate the LED chip(s) from the motherboard.
    • Refer to this guide for soldering and desoldering tips.
  12. Lego Dimensions Starter Pack Motherboard Replacement, Motherboard: 12 단계, 이미지 1/1
    • Separate the motherboard from both LED chips.
결론
Alyssa Lach
회원 가입일: 11/06/17
509 평판
안내서 4개 작성하였습니다
IUPUI, Team S5-G2, Baechle Fall 2017 IUPUI, Team S5-G2, Baechle Fall 2017 회원
IUPUI-BAECHLE-F17S5G2
2 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 11
전체 시간: 626
