주요 콘텐츠로 건너뛰기
Lenovo 100s Chromebook-11IBY Battery Replacement
필요한 것
  1. Lenovo 100s Chromebook-11IBY Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure your device is turned off and unplugged.
  2. Lenovo 100s Chromebook-11IBY Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Use a Phillips #0 screwdriver to remove the nine 6mm screws from the larger back plate.
  3. Lenovo 100s Chromebook-11IBY Battery Replacement: 3 단계, 이미지 2개 중 1개 Lenovo 100s Chromebook-11IBY Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Turn your laptop back over, open it, and use the plastic opening tool on the recessed notch to gently pry each side and lift the keyboard plate up.
    • Be careful not to pull keyboard plate out immediately because cables are attached.
  4. Lenovo 100s Chromebook-11IBY Battery Replacement: 4 단계, 이미지 2개 중 1개 Lenovo 100s Chromebook-11IBY Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Unlock the keyboard ZIF connector to release the keyboard flex cable.
    • To unlock a ZIF connector, use an opening tool or your fingernail to flip up the small, hinged locking flap.
    • Unlock the touchpad ZIF connector to release the touchpad flex cable.
    • Carefully pull both flex cables out of the ZIF connectors.
    • Remove the keyboard plate up and place it to the side.
  5. Lenovo 100s Chromebook-11IBY Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Unplug the battery cable by pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo 100s Chromebook-11IBY Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Use the Phillips #0 screwdriver to remove the three 6mm screws from the battery.
  7. Lenovo 100s Chromebook-11IBY Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the battery.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Milton Perez
회원 가입일: 03/09/17
630 평판
안내서 5개를 작성함
USF Tampa, Team S7-G2, Cagle Spring 2017 USF Tampa, Team S7-G2, Cagle Spring 2017 회원
USFT-CAGLE-S17S7G2
1 회원
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 2,574
