주요 콘텐츠로 건너뛰기
Lenovo 500e Chromebook 2nd Gen Motherboard Replacement
필요한 것
  1. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove nine 6 mm screws from the bottom cover of the laptop using a Phillips #0 screwdriver.
  2. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 2 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 2 단계, 이미지 2/2
    • Remove stylus from the lower left corner of the back panel.
  3. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 3 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 3 단계, 이미지 2/2
    • Go along the edge of the back panel with an iFixit opening tool until it pops loose.
    • Remove the back panel from the laptop.
  4. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the four 4 mm Phillips #00 screws holding the battery in.
  5. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 5 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 5 단계, 이미지 2/2
    • Use the iFixit opening tool to unplug the battery from the motherboard.
    • Potential for device damage: Make sure to be gentle while removing the wire.
  6. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the battery from the laptop.
  7. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Remove the three 4 mm screws (six total) from the left and right side brackets using a Phillips #00 screwdriver.
    • Gently remove the metal brackets from the motherboard.
  8. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 8 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 8 단계, 이미지 2/2
    • Remove the nine 4 mm screws from the motherboard using a Phillips #00 screwdriver.
  9. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 9 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 9 단계, 이미지 2/2
    • Gently remove the USB port from the side housing using an iFixit opening tool.
  10. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 10 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 10 단계, 이미지 2/2
    • Gently peel the metal strip away from the metal backing.
  11. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 11 단계, 이미지 1/1
    • Remove the single 3 mm screw that holds the Wi-Fi card in place using a Phillips #00 screwdriver.
  12. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 12 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 12 단계, 이미지 2/2
    • Disconnect the Wi-Fi card from the motherboard using an iFixit opening tool.
  13. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 13 단계, 이미지 1/3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 13 단계, 이미지 2/3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 13 단계, 이미지 3/3
    • Using an iFixit opening tool, disconnect the camera cable.
    • Potential for device damage: Be gentle while removing the wire.
  14. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 14 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 14 단계, 이미지 2/2
    • Using an iFixit opening tool, detach the speaker wiring from the motherboard.
    • Set speakers aside for reinstallation.
  15. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 15 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 15 단계, 이미지 2/2
    • Using an iFixit opening tool, detach the track pad connector from the motherboard.
    • Potential for device damage: Be gentle while detaching the connector.
  16. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 16 단계, 이미지 1/3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 16 단계, 이미지 2/3 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 16 단계, 이미지 3/3
    • Using an iFixit opening tool, detach the keyboard cable from the motherboard.
    • Potential for device damage: Be gentle when detaching the cable.
  17. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 17 단계, 이미지 1/2 Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 17 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, disconnect the black cable from the motherboard.
    • Potential for device damage: Be gentle while detaching the cable.
  18. Lenovo 500e Chromebook 2nd Gen Motherboard Replacement: 18 단계, 이미지 1/1
    • Gently remove the motherboard from the laptop.
결론
Nicolas Lidinsky
회원 가입일: 01/09/22
701 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 31
전체 시간: 758
