주요 콘텐츠로 건너뛰기
Lenovo Essential G560 Individual Keyboard Keys Replacement
  1. Lenovo Essential G560 Individual Keyboard Keys Replacement, Battery: 1 단계, 이미지 1/1
    • Turn off the computer.
    • Disconnect the charging cable from the computer.
    • Failure to unplug the cable could result in electric shock.
    • Flip the computer upside down.
  2. Lenovo Essential G560 Individual Keyboard Keys Replacement: 2 단계, 이미지 1/2 Lenovo Essential G560 Individual Keyboard Keys Replacement: 2 단계, 이미지 2/2
    • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
  3. Lenovo Essential G560 Individual Keyboard Keys Replacement: 3 단계, 이미지 1/1
    • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
  4. Lenovo Essential G560 Individual Keyboard Keys Replacement, Individual Keyboard Keys: 4 단계, 이미지 1/1
    • Place your pointer finger under the key you want to remove. For extra leverage, use the thumb and rotate the key in the manner shown.
  5. Lenovo Essential G560 Individual Keyboard Keys Replacement: 5 단계, 이미지 1/1
    • The key will come off with a popping sound.
    • You will now be able to see the mechanism below the key. Clean this area using compressed air, then replace the key.
결론
To reassemble your keyboard, push the key back into the original spot.
다른 8명이 해당 안내서를 완성하였습니다.
Lawrence Downs
회원 가입일: 01/11/13
383 평판
안내서 2개 작성하였습니다
Cal Poly, Team 18-40, Regan Winter 2013 Cal Poly, Team 18-40, Regan Winter 2013 회원
CPSU-REGAN-W13S18G40
5 회원들
안내서 7개 작성하였습니다
댓글 2개
I used your guide to install the key, thank you. I bought my lenovo keys from this link below
http://www.replacementlaptopkeys.com/len...
keep up the good work.
Resteasy - 답글
Hello , you can buy single keys on this site:
http://www.laptopkey-europe.eu/
John Pohl - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 15
전체 시간: 8,601
