주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo Essential G560 Keyboard Replacement
필요한 것
    1. Lenovo Essential G560 Keyboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Turn off the computer.
      • Disconnect the charging cable from the computer.
      • Failure to unplug the cable could result in electric shock.
      • Flip the computer upside down.
      댓글 쓰기
    2. Lenovo Essential G560 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Essential G560 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
      • Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
      댓글 쓰기
    3. Lenovo Essential G560 Keyboard Replacement: 3 단계, 이미지 1개 중 1개
      • Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
      댓글 쓰기
    1. Lenovo Essential G560 Keyboard Replacement, Back Panel: 4 단계, 이미지 1개 중 1개
      • Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
      댓글 쓰기
    2. Lenovo Essential G560 Keyboard Replacement: 5 단계, 이미지 2개 중 1개 Lenovo Essential G560 Keyboard Replacement: 5 단계, 이미지 2개 중 2개
      • Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
      • If the back panel is difficult to remove and feels like it is going to break, DO NOT force it. Check to confirm that all the screws are removed before attempting again.
      댓글 쓰기
    3. Lenovo Essential G560 Keyboard Replacement: 6 단계, 이미지 1개 중 1개
      • The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
      댓글 쓰기
    1. Lenovo Essential G560 Keyboard Replacement, Keyboard: 7 단계, 이미지 1개 중 1개
      • Remove the two 5.3 mm Phillips #1 screws from the underside of the laptop computer.
      • Remove the 4.4 mm Phillips #1 screw located next to the Fan Assembly.
      댓글 쓰기
    2. Lenovo Essential G560 Keyboard Replacement: 8 단계, 이미지 1개 중 1개
      • Flip the computer over.
      • Using the plastic opening tool, push in the four small, plastic tabs located at the top of the keyboard.
      댓글 쓰기
    3. Lenovo Essential G560 Keyboard Replacement: 9 단계, 이미지 1개 중 1개
      • Remove the keyboard by gently pulling the top loose, and then lifting the keyboard out.
      • While this step can be accomplished using your hand, it may be easier to use a spudger or plastic opening tool.
      댓글 쓰기
    4. Lenovo Essential G560 Keyboard Replacement: 10 단계, 이미지 1개 중 1개
      • Lift the keyboard up from the bezel.
      • Push the gray latch on the keyboard cable ZIF connector forward to unlock it.
      • Carefully pull the keyboard cable from its socket.
      • Be very careful while unlatching the lock on the keyboard cable ZIF connector. It is extremely delicate and can easily break.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 13명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Dennis Wong
회원 가입일: 01/11/13
618 평판
안내서 5개를 작성함
Cal Poly, Team 18-40, Regan Winter 2013 Cal Poly, Team 18-40, Regan Winter 2013 회원
CPSU-REGAN-W13S18G40
5 회원들
안내서 13개를 작성함
2가이드 댓글
Thank you frndzz
Anand krishnan - 답글 공유
Thank you frndz
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 56
전체 시간: 19,541
