주요 콘텐츠로 건너뛰기
Lenovo Essential G580 Optical Drive Replacement
필요한 것
  1. Lenovo Essential G580 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/1
    • Locate the removable portion on the bottom of the laptop.
  2. Lenovo Essential G580 Optical Drive Replacement: 2 단계, 이미지 1/1
    • Using a size 00 Phillips Head screwdriver, remove the two M2.5x4 screws connecting the removable plate to the frame of the computer.
  3. Lenovo Essential G580 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Using both hands, slide the plate off of the back of the laptop.
  4. Lenovo Essential G580 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Remove the M2.5x6 screw that fastens the optical drive to the laptop.
  5. Lenovo Essential G580 Optical Drive Replacement: 5 단계, 이미지 1/1
    • Using a spudger, push against the portion of the drive that was fastened. Be sure to push the drive outward as though it was opening. This completely ejects the device and prepares the laptop for a replacement part.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Tyler Robbins
회원 가입일: 03/02/17
182 평판
안내서 1개 작성함
USF Tampa, Team S13-G3, Cagle Spring 2017 USF Tampa, Team S13-G3, Cagle Spring 2017 회원
USFT-CAGLE-S17S13G3
4 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 17
전체 시간: 2,043
