주요 콘텐츠로 건너뛰기
Lenovo G50-80 80E5 Battery Replacement
  1. Lenovo G50-80 80E5 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Place laptop on a flat surface with the back cover facing up and the hinges facing you.
  2. Lenovo G50-80 80E5 Battery Replacement: 2 단계, 이미지 1/3 Lenovo G50-80 80E5 Battery Replacement: 2 단계, 이미지 2/3 Lenovo G50-80 80E5 Battery Replacement: 2 단계, 이미지 3/3
    • Slide the tab positioned on the right side to the right.
    • You will know this has been done correctly when you can see the red surface beneath the tab.
  3. Lenovo G50-80 80E5 Battery Replacement: 3 단계, 이미지 1/3 Lenovo G50-80 80E5 Battery Replacement: 3 단계, 이미지 2/3 Lenovo G50-80 80E5 Battery Replacement: 3 단계, 이미지 3/3
    • Move the left tab to the left to release the battery.
    • You will hear an audible 'click' and see the battery separate from the rest of the laptop.
  4. Lenovo G50-80 80E5 Battery Replacement: 4 단계, 이미지 1/3 Lenovo G50-80 80E5 Battery Replacement: 4 단계, 이미지 2/3 Lenovo G50-80 80E5 Battery Replacement: 4 단계, 이미지 3/3
    • Hold the battery at the top seam between it and the laptop.
    • Roll the battery towards yourself.
    • Lift the battery out of the laptop.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Abigail Hood
회원 가입일: 10/17/17
387 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S1-G6, Simcock Fall 2017 UMass Dartmouth, Team S1-G6, Simcock Fall 2017 회원
UMASSD-SIMCOCK-F17S1G6
4 회원들
안내서 10개 작성하였습니다
댓글 한 개
I purchased a new battery. I think I have not put the new one correctly. It does not align right. The computer is working fine. But it does not charge until I place a couple of books under the battery case, to kind of keep it in place..
Ashish Nelson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 35
전체 시간: 4,607
