주요 콘텐츠로 건너뛰기
Lenovo IdeaPad 330S-14IKB Battery Replacement
필요한 것
  1. Lenovo IdeaPad 330S-14IKB Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Begin by turning your laptop upside down so that you can access the labels on the back.
  2. Lenovo IdeaPad 330S-14IKB Battery Replacement: 2 단계, 이미지 1/2 Lenovo IdeaPad 330S-14IKB Battery Replacement: 2 단계, 이미지 2/2
    • Remove the 10 screws from the bottom of the laptop.
    • Safely store these screws in a place where you won't lose them, such as a magnetic pad.
    • (Silver, 5.8mm Philips #0)
  3. Lenovo IdeaPad 330S-14IKB Battery Replacement: 3 단계, 이미지 1/1
    • Slowly and carefully remove the back panel from the laptop.
    • Be cautious and use wedges if needed to avoid damaging the panel.
  4. Lenovo IdeaPad 330S-14IKB Battery Replacement: 4 단계, 이미지 1/1
    • Locate the battery in the bottom left corner.
  5. Lenovo IdeaPad 330S-14IKB Battery Replacement: 5 단계, 이미지 1/1
    • Remove the 5 screws that secure the battery in place.
    • (Black, 3.45mm Phillips #0)
  6. Lenovo IdeaPad 330S-14IKB Battery Replacement: 6 단계, 이미지 1/2 Lenovo IdeaPad 330S-14IKB Battery Replacement: 6 단계, 이미지 2/2
    • Near the positive and negative symbols on the battery, you'll find a wire connected to the motherboard.
    • Gently unplug this wire.
  7. Lenovo IdeaPad 330S-14IKB Battery Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad 330S-14IKB Battery Replacement: 7 단계, 이미지 2/2
    • There is a wire clipped to the side of the battery next to the hard drive; unhook this wire.
    • With the wire disconnected, remove the old battery.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Chris
회원 가입일: 09/28/23
229 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 15
전체 시간: 246
