주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 2 단계, 이미지 3/3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 3 단계, 이미지 2/2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Battery: 4 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 5 단계, 이미지 3/3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Hard Drive: 6 단계, 이미지 1/1
    • Remove the three 5 mm Phillips #00 screws that secure the hard drive.
  7. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 7 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 7 단계, 이미지 2/2
    • Using your hands, gently pull the hard drive back, sliding it out from the port.
  8. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Fan: 8 단계, 이미지 1/1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  9. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 9 단계, 이미지 1/1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  10. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 10 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 10 단계, 이미지 2/2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  11. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Heatsink: 11 단계, 이미지 1/1
  12. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 12 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 12 단계, 이미지 2/2
    • Carefully remove the heatsink from the device.
    • During reassembly, don't forget to apply thermal paste onto the heatsink. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
  13. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: 13 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: 13 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Speakers: 13 단계, 이미지 3/3
    • Using the iFixit nylon tipped tweezers, disconnect the wire that connects the speakers to the motherboard.
  14. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 14 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 14 단계, 이미지 2/2
    • Using your hands, gently pull the left speaker up and out of the device.
  15. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 15 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 15 단계, 이미지 2/2
    • Repeat the previous step for the other speaker and remove the speakers from the device.
  16. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Motherboard: 16 단계, 이미지 1/1
    • Using the Phillips #00 screwdriver, remove the three 5 mm Phillips #00 screws securing the motherboard.
  17. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 17 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 17 단계, 이미지 2/2
    • Disconnect the auxiliary port cable from the motherboard.
  18. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 18 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 18 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 18 단계, 이미지 3/3
    • Using a plastic opening tool, unlock the four ZIF connectors of the flat cables.
    • Lift up the connector locking tab and disconnect the cables from the motherboard.
  19. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 19 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 19 단계, 이미지 2/2
    • Disconnect the display cable from the motherboard.
  20. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 20 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 20 단계, 이미지 2/2
    • Using the plastic opening tool, unlock the connector for the side ports panel and disconnect the cable from the motherboard.
  21. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 21 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 21 단계, 이미지 2/2
    • Carefully lift and remove the motherboard from the device.
  22. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Display Assembly: 22 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement, Display Assembly: 22 단계, 이미지 2/2
    • Using the Phillips #00 screwdriver, remove the four total 5 mm screws from the left and right hinges (two screws on each hinge).
    • For proper screwdriver technique, please visit the Screwdriver Best Practices guide.
  23. Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 23 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Display Assembly Replacement: 23 단계, 이미지 2/2
    • Disconnect the display assembly from the rest of the device.
결론
Justin Ogihara
회원 가입일: 09/18/17
27,230 평판
안내서 52개 작성하였습니다
EDU Team EDU Team 회원
Staff
7 회원들
안내서 637개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 26
30일 전: 124
전체 시간: 4,383
