주요 콘텐츠로 건너뛰기
Lenovo IdeaPad Flex 5-1570 Heatsink Replacement
필요한 것
  1. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Back Panel: 1 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Back Panel: 1 단계, 이미지 2/2
    • Remove the ten 5 mm Phillips #00 screws that are holding the back panel on.
  2. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 2 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 2 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 2 단계, 이미지 3/3
    • Use a spudger to pry open the back case at the two hinge cutouts.
    • Gently use the plastic opening tool around the edges of the laptop to pry up the clips holding the rest of the back panel.
  3. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 3 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 3 단계, 이미지 2/2
    • Once all the clips have been disengaged, lift off the back cover.
  4. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Battery: 4 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Battery: 4 단계, 이미지 2/2
    • Remove the two 5 mm Phillips #00 screws that secure the battery in place.
  5. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 5 단계, 이미지 1/3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 5 단계, 이미지 2/3 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 5 단계, 이미지 3/3
    • Using your fingers, grasp the entire bundle of wires to pull the battery cable from its connector. This will cut off power to the motherboard.
    • Be sure to apply even pressure across the wires and connector to not damage the battery cable.
    • Remove the battery from the device.
  6. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Fan: 6 단계, 이미지 1/1
    • Remove the two 5 mm Phillips #00 screws that secure the fan in place.
  7. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 7 단계, 이미지 1/1
    • Using your hands, remove the wire that is wrapped around the base of the fan.
  8. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 8 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 8 단계, 이미지 2/2
    • Disconnect the wire holding the fan and the motherboard together.
    • Remove the fan from the device.
  9. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement, Heatsink: 9 단계, 이미지 1/1
  10. Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 10 단계, 이미지 1/2 Lenovo IdeaPad Flex 5-1570 Heatsink Replacement: 10 단계, 이미지 2/2
    • Carefully remove the heatsink from the device.
    • During reassembly, don't forget to apply thermal paste onto the heatsink. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
결론
Don’t forget to reapply thermal paste during reassembly. For proper technique on thermal paste application, please visit the How to Apply Thermal Paste guide.
다른 한 분이 해당 안내서를 완성하였습니다.
Justin Ogihara
회원 가입일: 09/18/17
27,230 평판
안내서 52개 작성하였습니다
EDU Team EDU Team 회원
Staff
7 회원들
안내서 637개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 43
전체 시간: 788
