주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-15IAP Battery Replacement
필요한 것
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: 1 단계, 이미지 1/2 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: 2 단계, 이미지 1/1
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: 3 단계, 이미지 1/1
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: 4 단계, 이미지 1/2 Lenovo Ideapad 320-15IAP Battery Replacement: 4 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: 5 단계, 이미지 1/2 Lenovo Ideapad 320-15IAP Battery Replacement: 5 단계, 이미지 2/2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 한 분이 해당 안내서를 완성하였습니다.
Franco Criscola
회원 가입일: 01/30/20
901 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 8
30일 전: 45
전체 시간: 1,202
