소개
This guide for the Lenovo IdeaPad 320-17IKB will show the user how to remove the front LED assembly for replacement.
An LED screen is the flat display panel that portrays the images seen on the laptop. It does this through the use of light emitting pixels. Be careful not to bend or twist the LED screen during removal as it can damage the component.
Before replacing this LED screen, check out the Lenovo IdeaPad 320-17IKB Troubleshooting.
필요한 것
Start from the left side of the bezel (plastic covering) by gently removing inner edge of the plastic. Continue to do the same thing on the right side.
다른 3명이 해당 안내서를 완성하였습니다.
