주요 콘텐츠로 건너뛰기
Lenovo Ideapad 320-17IKB LED Screen Replacement
필요한 것
  1. Lenovo Ideapad 320-17IKB LED Screen Replacement, LED Screen: 1 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB LED Screen Replacement, LED Screen: 1 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB LED Screen Replacement, LED Screen: 1 단계, 이미지 3/3
    • Start from the left side of the bezel (plastic covering) by gently removing inner edge of the plastic. Continue to do the same thing on the right side.
  2. Lenovo Ideapad 320-17IKB LED Screen Replacement: 2 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB LED Screen Replacement: 2 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB LED Screen Replacement: 2 단계, 이미지 3/3
    • Turn the laptop sideways and insert the plastic pick between the bezel (plastic covering) and the laptop cover. Use the plastic pick to separate the bezel from the top cover.
  3. Lenovo Ideapad 320-17IKB LED Screen Replacement: 3 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB LED Screen Replacement: 3 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB LED Screen Replacement: 3 단계, 이미지 3/3
    • Remove the bezel (plastic covering) from the laptop completely and set aside.
    • Do not twist or bend the LED screen or the bezel. Doing so could result in permanent damage to the LED screen or injury to yourself.
  4. Lenovo Ideapad 320-17IKB LED Screen Replacement: 4 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB LED Screen Replacement: 4 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB LED Screen Replacement: 4 단계, 이미지 3/3
    • Remove the four 7mm JIS #00 screws from each corner while holding the screen in place.
  5. Lenovo Ideapad 320-17IKB LED Screen Replacement: 5 단계, 이미지 1/3 Lenovo Ideapad 320-17IKB LED Screen Replacement: 5 단계, 이미지 2/3 Lenovo Ideapad 320-17IKB LED Screen Replacement: 5 단계, 이미지 3/3
    • Place the LED screen on the keyboard and use your fingers or the iFixit opening tool to open the bracket securing the video connector. Then, disconnect the video cable.
  6. Lenovo Ideapad 320-17IKB LED Screen Replacement: 6 단계, 이미지 1/2 Lenovo Ideapad 320-17IKB LED Screen Replacement: 6 단계, 이미지 2/2
    • Once all the other steps have been completed you should have a disconnected LED screen, and bezel. The connector tab should remain adhered to the motherboard.
결론
다른 3명이 해당 안내서를 완성하였습니다.
a1235
회원 가입일: 09/02/19
611 평판
안내서 3개 작성하였습니다
댓글 2개
Is there a direct replacement better quality panel?
Jason - 답글
does this laptop have backlights on keyboard ????????
P SANDEEP - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 8
30일 전: 46
전체 시간: 1,693
