주요 콘텐츠로 건너뛰기
Lenovo Legion Y530-15ICH Battery Replacement
필요한 것
  1. Lenovo Legion Y530-15ICH Battery Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Battery Replacement: 2 단계, 이미지 2개 중 1개 Lenovo Legion Y530-15ICH Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Battery Replacement: 4 단계, 이미지 2개 중 1개 Lenovo Legion Y530-15ICH Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 10명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kaylie Klausing
회원 가입일: 02/07/20
806 평판
안내서 6개를 작성함
Cal Poly, Team S7-G1, Regan Winter 2020 Cal Poly, Team S7-G1, Regan Winter 2020 회원
CPSU-REGAN-W20S7G1
4 회원들
안내서 12개를 작성함
5가이드 댓글
Hello! I have a Lenovo Y530 laptop and its battery is swollen. After removing the battery and waiting for the replacement, can I directly plug in the laptop to the power without having the battery?
Joshua Luna - 답글
Hi Joshua,
Yes! Be careful to reassemble everything other than the laptop. The laptop should boot, though depending on the brand and model, some will refuse without a battery.
Arthur Shi -
dobry den mohu notebook zn. Lenovo Legion y530 zapnout i kdyz vytahnu baterii?dekuji
Roman Černobyl - 답글
你好,Roman。我的Lenovo Legion y530电池鼓包后可以正常使用,直到有一天关机后,接通电源适配器的情况下电脑后面的指示灯不亮了,按开机键也无法开机,于是我知道是时候换电池了。取出电池后发现它严重鼓包,最厚处为正常情况下的3到4倍。取出电池合上后盖后插电源没有反应无法开机,我当时以为电脑主板坏了。如果你遇到以上问题,请不要担心,正常使用不跌落不进水的情况下电脑应该没有坏。我给电脑更换新的L17C3PG1电池后,合上后盖,不插电源适配器,长按开机键至少15秒后松开,如此操作大概1分钟就开机了,此时插上电源适配器后就可以正常使用了。记得拧上后盖螺丝。
marxlan -
Lenovo Legion y530电池鼓包会有预兆的,正常没有跌落没有进水的情况下,如果某天你发现触控板没有反应了,那很有可能是因为电池轻微鼓包导致触控板位置的排线被电池鼓包顶起松动了,如果你平时不用触控板可以先等等更换电池(但是我建议尽快更换新电池,以防危险和不必要的损失发生)。在已知自己电脑电池鼓包的情况下,如果有一天发现触控板高于触控板的物理按键,或者电脑高负载使用时屏幕突然全黑,或者桌面突然消失任务管理器重启等异常情况,请抓紧换新电池吧。对于Lenovo Legion y530来说,L17C3PG1、L17C3PG2和L17C3PG3这3种型号的电池是通用的,对于长期接通电源适配器的用户来说没有区别。
marxlan - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 22
지난 30일: 75
전체 시간: 16,378
