주요 콘텐츠로 건너뛰기
Lenovo Legion Y7000P RAM Replacement
필요한 것
  1. Lenovo Legion Y7000P RAM Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 1/2 Lenovo Legion Y7000P RAM Replacement, Prepare your laptop for disassembly: 1 단계, 이미지 2/2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo Legion Y7000P RAM Replacement, Flip your laptop over: 2 단계, 이미지 1/1
    • Flip your laptop over so the rubber feet are facing up.
  3. Lenovo Legion Y7000P RAM Replacement, Unfasten the back cover: 3 단계, 이미지 1/2 Lenovo Legion Y7000P RAM Replacement, Unfasten the back cover: 3 단계, 이미지 2/2
    • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
    • Five 11.5 mm‑long screws
    • Six 4.7 mm-long screws
  4. Lenovo Legion Y7000P RAM Replacement, Insert an opening pick: 4 단계, 이미지 1/2 Lenovo Legion Y7000P RAM Replacement, Insert an opening pick: 4 단계, 이미지 2/2
    • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
  5. Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: 5 단계, 이미지 1/3 Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: 5 단계, 이미지 2/3 Lenovo Legion Y7000P RAM Replacement, Release the back cover's clips: 5 단계, 이미지 3/3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Keep the pick angled upwards while sliding to help release the clips.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Lenovo Legion Y7000P RAM Replacement: 6 단계, 이미지 1/3 Lenovo Legion Y7000P RAM Replacement: 6 단계, 이미지 2/3 Lenovo Legion Y7000P RAM Replacement: 6 단계, 이미지 3/3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Lenovo Legion Y7000P RAM Replacement, Remove the back cover: 7 단계, 이미지 1/3 Lenovo Legion Y7000P RAM Replacement, Remove the back cover: 7 단계, 이미지 2/3 Lenovo Legion Y7000P RAM Replacement, Remove the back cover: 7 단계, 이미지 3/3
    • Remove the back cover.
  8. Lenovo Legion Y7000P RAM Replacement, Reassembly information: 8 단계, 이미지 1/3 Lenovo Legion Y7000P RAM Replacement, Reassembly information: 8 단계, 이미지 2/3 Lenovo Legion Y7000P RAM Replacement, Reassembly information: 8 단계, 이미지 3/3
    • During reassembly:
    • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
    • Press down firmly around the perimeter of the back cover to engage all the clips.
  9. Lenovo Legion Y7000P RAM Replacement, Heat the black cover: 9 단계, 이미지 1/2 Lenovo Legion Y7000P RAM Replacement, Heat the black cover: 9 단계, 이미지 2/2
    • A stiff, black cover runs across the heatsink and fans.
    • Removing the cover makes repairs much easier, but isn't required. If you don't want to remove the cover, you can roll it onto itself to keep it out of the way and skip the next two steps.
    • Heat an iOpener and apply it to the cover for two minutes.
    • You can also use a hair dryer. Follow this guide for more instructions.
  10. Lenovo Legion Y7000P RAM Replacement, Remove the cover: 10 단계, 이미지 1/3 Lenovo Legion Y7000P RAM Replacement, Remove the cover: 10 단계, 이미지 2/3 Lenovo Legion Y7000P RAM Replacement, Remove the cover: 10 단계, 이미지 3/3
    • Gently peel up and remove the black cover.
    • During reassembly, press the cover back into place using the residual adhesive.
  11. Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: 11 단계, 이미지 1/3 Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: 11 단계, 이미지 2/3 Lenovo Legion Y7000P RAM Replacement, Disconnect the battery: 11 단계, 이미지 3/3
    • Use the flat end of a spudger to push the battery connector straight out of its socket.
    • Push the tab on top of the battery connector, not the wires themselves.
  12. Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: 12 단계, 이미지 1/3 Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: 12 단계, 이미지 2/3 Lenovo Legion Y7000P RAM Replacement, Pry up the metal shield: 12 단계, 이미지 3/3
    • A metal shield covers the sticks of RAM.
    • Use a spudger to pry up the left side of the metal shield.
  13. Lenovo Legion Y7000P RAM Replacement, Remove the metal shield: 13 단계, 이미지 1/2 Lenovo Legion Y7000P RAM Replacement, Remove the metal shield: 13 단계, 이미지 2/2
    • Remove the metal shield.
    • During reassembly, align the shield with its metal clips and press down firmly around the perimeter to secure the shield.
  14. Lenovo Legion Y7000P RAM Replacement, Remove the RAM: 14 단계, 이미지 1/3 Lenovo Legion Y7000P RAM Replacement, Remove the RAM: 14 단계, 이미지 2/3 Lenovo Legion Y7000P RAM Replacement, Remove the RAM: 14 단계, 이미지 3/3
    • Two metal arms secure each stick of RAM.
    • Simultaneously push out the arms until they disengage and the stick pops up at a slight angle.
    • Remove the stick of RAM.
    • Repeat the process to remove the other stick of RAM.
    • To install a stick of RAM, insert it into its socket at a slight downward angle and push down firmly until both metal arms lock the stick in place.
결론
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
회원 가입일: 09/14/22
54,804 평판
안내서 407개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,288개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 21
전체 시간: 138
