주요 콘텐츠로 건너뛰기
Lenovo ThinkPad Edge E420s Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad Edge E420s Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • There is no external access to the battery. Please make sure the at the battery has been drained or disabled through BIOS before beginning.
    • Flip the device over.
  2. Lenovo ThinkPad Edge E420s Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove one M2 x 3mm screw from the side of the device.
  3. Lenovo ThinkPad Edge E420s Hard Drive Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: 3 단계, 이미지 3/3
    • Swing the cover out slightly like a hinge.
    • Pull the cover directly away from the case towards the base of the laptop.
    • Lift the cover up and away from the device to remove it.
    • You may hear a slight pop when you pull the cover off.
  4. Lenovo ThinkPad Edge E420s Hard Drive Replacement: 4 단계, 이미지 1/1
    • Use the clear tab to slide the hard drive out of the device.
  5. Lenovo ThinkPad Edge E420s Hard Drive Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad Edge E420s Hard Drive Replacement: 5 단계, 이미지 3/3
    • To replace the hard drive, remove the four M2 × 4mm wafer-headed screws on the sides of the hard drive case using a Phillips #00 screwdriver.
    • Slide the old hard drive directly out.
    • When reassembling, make sure the hard drive is securely in the case before beginning.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Keyadri Summerlin
회원 가입일: 10/02/18
1,003 평판
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 9
30일 전: 38
전체 시간: 2,837
