주요 콘텐츠로 건너뛰기
Lenovo ThinkPad L440 Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad L440 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 1개 Lenovo ThinkPad L440 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 2개 Lenovo ThinkPad L440 Keyboard Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 Keyboard Replacement: 2 단계, 이미지 1개 중 1개
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 Keyboard Replacement: 3 단계, 이미지 2개 중 1개 Lenovo ThinkPad L440 Keyboard Replacement: 3 단계, 이미지 2개 중 2개
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 Keyboard Replacement, Keyboard‎: 4 단계, 이미지 3개 중 1개 Lenovo ThinkPad L440 Keyboard Replacement, Keyboard‎: 4 단계, 이미지 3개 중 2개 Lenovo ThinkPad L440 Keyboard Replacement, Keyboard‎: 4 단계, 이미지 3개 중 3개
    • Insert the pointed end of a spudger into the notch on the left side first, and apply gentle pressure upwards until the frame around the keyboard moves up. Repeat for the other side.
    • The spudger used in this guide is NOT ESD-safe, so be cautious when working on your device.
  5. Lenovo ThinkPad L440 Keyboard Replacement: 5 단계, 이미지 1개 중 1개
    • Loosen the six captive screws using a Phillips #00 screwdriver.
  6. Lenovo ThinkPad L440 Keyboard Replacement: 6 단계, 이미지 3개 중 1개 Lenovo ThinkPad L440 Keyboard Replacement: 6 단계, 이미지 3개 중 2개 Lenovo ThinkPad L440 Keyboard Replacement: 6 단계, 이미지 3개 중 3개
    • Lift the edge of the keyboard using the blunt side of the spudger, and bring it straight up and out towards you. Lay the keyboard flat on top of the trackpad.
    • Be careful as the keyboard still has ribbon connectors connected to the laptop.
    • To reassemble, gently push down on all sides of the keyboard.
  7. Lenovo ThinkPad L440 Keyboard Replacement: 7 단계, 이미지 3개 중 1개 Lenovo ThinkPad L440 Keyboard Replacement: 7 단계, 이미지 3개 중 2개 Lenovo ThinkPad L440 Keyboard Replacement: 7 단계, 이미지 3개 중 3개
    • Pull the black latch over the connectors up towards the screen with your nail.
    • Grab onto the blue part and, with gentle pressure, pull straight back towards you to release the ribbon cable.
    • Repeat for the second, smaller ribbon connector.
    • These parts are fragile, and can tear easily, so take your time, go gently, and make sure to pull straight towards you.
결론
To reassemble, follow this guide in reverse order. Once completed, power on the laptop and test the new keyboard.
작성자
1다른 기여자 명과 함께
Brendin Melo
회원 가입일: 10/18/24
109 평판
안내서 1개를 작성함
UMass Dartmouth, Team 2-6, Konn Fall 2024 UMass Dartmouth, Team 2-6, Konn Fall 2024 회원
UMASSD-KONN-F24S2G6
4 회원들
안내서 5개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 9
지난 7일: 18
지난 30일: 61
전체 시간: 171
