주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T430s CMOS Battery Replacement
필요한 것
  1. Lenovo ThinkPad T430s CMOS Battery Replacement, Motherboard: 1 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement, Motherboard: 1 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement, Motherboard: 1 단계, 이미지 3/3
    • Flip your ThinkPad over so the back faces up.
    • With the Phillips #0 screwdriver, remove the seven 50 mm screws on the outer edge of the case.
    • Remove the two 70 mm screws in the upper corners of the case.
    • Remove the five 50 mm screws in the battery compartment.
  2. Lenovo ThinkPad T430s CMOS Battery Replacement: 2 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 2 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 2 단계, 이미지 3/3
    • In the RAM compartment, pry the black, white, and grey wires up from the Wi-Fi card with the pointy end of the spudger.
    • Remove the 30 mm screw holding down the Wi-Fi card with the Phillips #0 screwdriver.
    • Pull out the Wi-Fi card.
    • Remove the 60 mm and 30 mm screws in the RAM stick compartment.
  3. Lenovo ThinkPad T430s CMOS Battery Replacement: 3 단계, 이미지 1/1
    • Remove the 50 mm and 30 mm screws in the hard drive compartment.
  4. Lenovo ThinkPad T430s CMOS Battery Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 4 단계, 이미지 3/3
    • Flip the ThinkPad right side up and open the lid.
    • Wedge the flat end of the spudger between the keyboard and the palm rest. Push the keyboard away from you until it pops out.
    • Lift the keyboard from the palm rest to expose the ribbon connecting the keyboard to the motherboard.
    • Pry the keyboard ribbon up from the motherboard with the flat end of the spudger.
    • Set the keyboard aside.
  5. Lenovo ThinkPad T430s CMOS Battery Replacement: 5 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 5 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 5 단계, 이미지 3/3
    • Remove the two 50 mm screws from the case covering the disk drive.
    • Thread the wires that come from the RAM compartment up through the hole in the motherboard. Unwind them from the computer case.
    • Wedge the flat end of the spudger in between the palm rest and the bottom case. Unsnap the edges of the palm rest and case until they disconnect.
    • Lift the palm rest up from the motherboard.
  6. Lenovo ThinkPad T430s CMOS Battery Replacement: 6 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 6 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 6 단계, 이미지 3/3
    • Pull the red, blue, and white wires in the left corner away from the motherboard.
    • Peel the snap securing the ribbon with the pointy end of the spudger.
    • Pull the ribbon back towards you.
  7. Lenovo ThinkPad T430s CMOS Battery Replacement: 7 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 7 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 7 단계, 이미지 3/3
    • Rotate the ThinkPad so the back side faces you.
    • With the Phillips #1 screwdriver, unscrew the two 70 mm screws from the corners.
    • Lift the screen and pull it out of the hinges. Set the screen down behind the rest of the ThinkPad.
  8. Lenovo ThinkPad T430s CMOS Battery Replacement: 8 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 8 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 8 단계, 이미지 3/3
    • With the pointy end of the spudger, lift the plastic snap holding down the SN4 LVDS cable. Pull the cable out of the clasp towards you.
    • Pry the SN4 LED cable out of where it connects to the motherboard.
    • Set the display aside.
  9. Lenovo ThinkPad T430s CMOS Battery Replacement: 9 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 9 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 9 단계, 이미지 3/3
    • With the pointy end of the spudger, lift the plastic snap securing the ribbon at the front of the ThinkPad.
    • Pull the ribbon out of the clasp towards you.
  10. Lenovo ThinkPad T430s CMOS Battery Replacement: 10 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 10 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 10 단계, 이미지 3/3
    • Unscrew the 90 mm screw, five 50 mm screws, and four 30 mm screws on the motherboard using a Phillips #0 screwdriver.
    • When you remove the screws, the small motherboard stick in the top right corner will pop out of the case. Pull it out.
    • Lift the motherboard out of the case.
  11. Lenovo ThinkPad T430s CMOS Battery Replacement: 11 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 11 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement: 11 단계, 이미지 3/3
    • Flip the motherboard over so the back faces up.
    • Loosen the four screws securing the heat sink to the motherboard. The silver metal rectangle on the front of the motherboard will fall off. Set it aside.
    • Lift the fan and heat sink away from the motherboard.
  12. Lenovo ThinkPad T430s CMOS Battery Replacement, CMOS Battery: 12 단계, 이미지 1/3 Lenovo ThinkPad T430s CMOS Battery Replacement, CMOS Battery: 12 단계, 이미지 2/3 Lenovo ThinkPad T430s CMOS Battery Replacement, CMOS Battery: 12 단계, 이미지 3/3
    • Flip the motherboard over and disconnect the CMOS battery from the motherboard by pulling the cable away from the connector.
    • It is important to note that the cable must be pulled evenly away from the connector to prevent damage to the connector or cable.
  13. Lenovo ThinkPad T430s CMOS Battery Replacement: 13 단계, 이미지 1/2 Lenovo ThinkPad T430s CMOS Battery Replacement: 13 단계, 이미지 2/2
    • Use a nylon spudger to slightly push against the white bundled cable connector while evenly pulling the cable from the other side.
    • Remove the CMOS battery from the motherboard.
결론
Noah Daniels
회원 가입일: 02/21/23
85 평판
안내서 1개 작성함
University of Kentucky, Team 1-11, Kaufmann Spring 2023 University of Kentucky, Team 1-11, Kaufmann Spring 2023 회원
UKY-KAUFMANN-S23S1G11
5 회원들
안내서 5개 작성하였습니다
댓글 4개
Why is it necessary to continue after Step 4 where the cmos battery already appears to be accessible?
Piko Faj - 답글
yes this is correct
Nathan Reeves -
Holy Crap! It's right under that square door right in the middle on the back! You only have to remove two screws!
Rex Dwyer - 답글
exactly! sort of an odd guide
Nathan Reeves -
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 30
30일 전: 189
전체 시간: 2,699
