주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T430s Hard Drive Replacement
필요한 것
  1. Lenovo ThinkPad T430s Hard Drive Replacement, Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T430s Hard Drive Replacement, Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T430s Hard Drive Replacement, Battery: 1 단계, 이미지 3/3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Hard Drive Replacement, Hard Drive: 2 단계, 이미지 1/1
    • Unscrew the 40 mm screw with the Phillips head #1 screwdriver.
  3. Lenovo ThinkPad T430s Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pull the hard drive out with the black ribbon attached to it.
결론
Melissa Rogers
회원 가입일: 09/02/20
681 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 73
전체 시간: 2,343
