주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T430s Keyboard Replacement
필요한 것
  1. Lenovo ThinkPad T430s Keyboard Replacement, Battery: 1 단계, 이미지 1/3 Lenovo ThinkPad T430s Keyboard Replacement, Battery: 1 단계, 이미지 2/3 Lenovo ThinkPad T430s Keyboard Replacement, Battery: 1 단계, 이미지 3/3
    • Flip your ThinkPad on its back.
    • In the bottom left corner of your ThinkPad, slide the lever to the left. Hold the lever there.
    • Use your other hand to lift the battery up by prying the notch to the left of the lever.
    • Tilt the battery up and remove it from the ThinkPad.
  2. Lenovo ThinkPad T430s Keyboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Flip the ThinkPad right side up and open the lid.
    • Use the spudger to wedge the keyboard from the case.
  3. Lenovo ThinkPad T430s Keyboard Replacement: 3 단계, 이미지 1/1
    • Lift the keyboard with your hands.
    • Pry the keyboard ribbon up from the motherboard with the flat end of the spudger.
    • Lift the keyboard from the case and find the ribbon press connector.
  4. Lenovo ThinkPad T430s Keyboard Replacement: 4 단계, 이미지 1/1
    • Use the spudger to lift the bottom right angle of the connector.
    • Remove the disconnected keyboard from the case.
결론
Cleophas Johnson III
회원 가입일: 02/21/23
97 평판
안내서 1개 작성함
University of Kentucky, Team 1-11, Kaufmann Spring 2023 University of Kentucky, Team 1-11, Kaufmann Spring 2023 회원
UKY-KAUFMANN-S23S1G11
5 회원들
안내서 5개 작성하였습니다
댓글 한 개
Do not forget to remove the screws in the memory and battery areas, if you don't the keyboard will NOT come off at all and you will most likely break your device.
Tenzin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 81
전체 시간: 897
