주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T460s Battery Replacement
필요한 것
  1. Lenovo ThinkPad T460s Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Remove the five 5.5mm Phillips #1 screws securing the back cover.
    • These screws are captive and cannot be removed completely from the back cover.
    • Lift and remove the back cover.
  2. Lenovo ThinkPad T460s Battery Replacement: 2 단계, 이미지 1/1
    • Remove the five 5.5mm Phillips #1 screws securing the two batteries.
  3. Lenovo ThinkPad T460s Battery Replacement: 3 단계, 이미지 1/1
    • Unplug the two-wire connector from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  4. Lenovo ThinkPad T460s Battery Replacement: 4 단계, 이미지 1/3 Lenovo ThinkPad T460s Battery Replacement: 4 단계, 이미지 2/3 Lenovo ThinkPad T460s Battery Replacement: 4 단계, 이미지 3/3
    • Each battery has a black tab covering the electrical contacts.
    • Lift the battery by its tab and remove it from the device.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
다른 13명이 해당 안내서를 완성하였습니다.
kewei xia
회원 가입일: 10/01/19
457 평판
안내서 2개 작성하였습니다
댓글 12개
I have a question, please. Are the two batteries identical?
Felipe L.R. - 답글
No, the batteries are different.
Battery 1 Part Number: 00HW022. (23.510 mWh)
Battery 2 Part Number: 01AV405. (26.330 mWh)
Best regards!
Rafael -
Hi there, anyone know which battery is number 1? - only battery 1 is broken in my laptop, 2 still works.
Jonas Andersen - 답글
Hello!!?? Any in iFixit knows the answer to Jonas’ question???
Ruben -
Battery 1 is 00HW022. (23.510 mWh)
Battery 2 is 01AV405. (26.330 mWh)
You can confirm it by yourself running powercfg /batteryreport on cmd
Hope it helps!
Rafael -
댓글 쓰기
조회 통계:
24 시간 전: 18
7일 전: 111
30일 전: 500
전체 시간: 49,669
