주요 콘텐츠로 건너뛰기
Lenovo ThinkPad T470s Motherboard Replacement
필요한 것
  1. Lenovo ThinkPad T470s Motherboard Replacement, Bottom Panel: 1 단계, 이미지 1/1
    • Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
    • Lift the bottom panel up and off the laptop.
  2. Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 2 단계, 이미지 1/3 Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 2 단계, 이미지 2/3 Lenovo ThinkPad T470s Motherboard Replacement, Batteries: 2 단계, 이미지 3/3
    • Remove two screws on the bottom of the upper battery using a Phillips #000 screwdriver.
    • Remove three screws on the top of the lower battery using a Phillips #000 screwdriver.
    • Peel back connecting supporting tape on each of the batteries.
  3. Lenovo ThinkPad T470s Motherboard Replacement: 3 단계, 이미지 1/3 Lenovo ThinkPad T470s Motherboard Replacement: 3 단계, 이미지 2/3 Lenovo ThinkPad T470s Motherboard Replacement: 3 단계, 이미지 3/3
    • Slide the upper battery out of the device, away from the laptop.
    • Slide the lower battery out of the device, away from the laptop.
  4. Lenovo ThinkPad T470s Motherboard Replacement, Fan and Heat Sink: 4 단계, 이미지 1/1
    • Loosen the four screws from the heatsink with a Phillips #000 screwdriver.
  5. Lenovo ThinkPad T470s Motherboard Replacement: 5 단계, 이미지 1/1
    • Unplug the fan from the motherboard.
  6. Lenovo ThinkPad T470s Motherboard Replacement: 6 단계, 이미지 1/1
    • Remove the heatsink and fan from the laptop.
  7. Lenovo ThinkPad T470s Motherboard Replacement: 7 단계, 이미지 1/1
    • Wipe off the old thermal paste with either 99% isopropyl alcohol or kimwipes.
  8. Lenovo ThinkPad T470s Motherboard Replacement: 8 단계, 이미지 1/2 Lenovo ThinkPad T470s Motherboard Replacement: 8 단계, 이미지 2/2
  9. Lenovo ThinkPad T470s Motherboard Replacement, Wi-Fi Card: 9 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw securing the Wi-Fi card.
    • The Wi-Fi card will lift to a slight angle after the screw is removed.
  10. Lenovo ThinkPad T470s Motherboard Replacement: 10 단계, 이미지 1/1
    • Grip the Wi-Fi card on both sides, then pull it directly out of its port.
  11. Lenovo ThinkPad T470s Motherboard Replacement, USB Board: 11 단계, 이미지 1/2 Lenovo ThinkPad T470s Motherboard Replacement, USB Board: 11 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the two 3.3 mm screws.
  12. Lenovo ThinkPad T470s Motherboard Replacement: 12 단계, 이미지 1/1
    • Use your fingernail to flip up the gate, then pull the connector directly out of the port.
  13. Lenovo ThinkPad T470s Motherboard Replacement: 13 단계, 이미지 1/1
    • Lift the USB board up and out of the chassis.
  14. Lenovo ThinkPad T470s Motherboard Replacement, SSD: 14 단계, 이미지 1/2 Lenovo ThinkPad T470s Motherboard Replacement, SSD: 14 단계, 이미지 2/2
    • Locate the SSD slot between the large battery and fan.
    • Remove the screw securing the SSD using a Phillips #000 screwdriver.
  15. Lenovo ThinkPad T470s Motherboard Replacement: 15 단계, 이미지 1/2 Lenovo ThinkPad T470s Motherboard Replacement: 15 단계, 이미지 2/2
    • Slide the SSD out of the motherboard.
  16. Lenovo ThinkPad T470s Motherboard Replacement, Motherboard: 16 단계, 이미지 1/2 Lenovo ThinkPad T470s Motherboard Replacement, Motherboard: 16 단계, 이미지 2/2
    • Flip up the locking gate, then pull the cable directly out of its port.
    • Use a Phillips #0 screwdriver to remove the single 3.3 mm screw on the top right corner of the motherboard.
  17. Lenovo ThinkPad T470s Motherboard Replacement: 17 단계, 이미지 1/1
    • Remove the single 3.3 mm screw with a Phillips #0 screwdriver.
  18. Lenovo ThinkPad T470s Motherboard Replacement: 18 단계, 이미지 1/1
  19. Lenovo ThinkPad T470s Motherboard Replacement: 19 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the single 2.9 mm screw.
  20. Lenovo ThinkPad T470s Motherboard Replacement: 20 단계, 이미지 1/2 Lenovo ThinkPad T470s Motherboard Replacement: 20 단계, 이미지 2/2
    • Disconnect the speaker connection covering the screw.
    • Use a Phillips #0 screwdriver to remove the single 5 mm screw securing the motherboard.
  21. Lenovo ThinkPad T470s Motherboard Replacement: 21 단계, 이미지 1/1
    • Remove the 3.3 mm screw using a Phillips #0 screwdriver.
  22. Lenovo ThinkPad T470s Motherboard Replacement: 22 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the 3.3 mm screw.
  23. Lenovo ThinkPad T470s Motherboard Replacement: 23 단계, 이미지 1/1
  24. Lenovo ThinkPad T470s Motherboard Replacement: 24 단계, 이미지 1/2 Lenovo ThinkPad T470s Motherboard Replacement: 24 단계, 이미지 2/2
    • Gently grip the motherboard and slide it to the right to remove the USB ports from the chassis.
    • You will hear an audible clicking sound.
    • Lift the motherboard up and out of the chassis.
결론
다른 2명이 해당 안내서를 완성하였습니다.
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 105
전체 시간: 2,792
