소개
If you experience hardware failure with the webcam of your Lenovo ThinkPad T480, you may want to replace it. This guide gives you the step by step instructions to remove the camera assembly.
It’s important to do a little troubleshooting prior to the repair to determine if your webcam issue is a hardware failure. The guide on the Lenovo support page will walk you through potential software issues that might be the cause of your problems.
Prior to beginning the repair, disable the internal battery, power off your device, and unplug the charging cable.
필요한 것
Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
Using the Phillips #1 screwdriver, loosen the four captive screws in the arm of the heatsink.
Using the black nylon spudger, lift the connector lock up.
Disconnect the storage cable from the system board.
Using the Phillips #1 screwdriver, remove three 4.6 mm screws from the I/O bracket.
Use the black nylon spudger to lift up the small locking flap on the power button cable's ZIF connector.
Slide the power button cable out of the ZIF connector.
Use the metal spudger to create a space between the bezel and lid and carefully undo the clips around the perimeter of the bezel.
Remove the four 3.0 mm Phillips #1 screws from the four corners of the LCD screen.
Lift it up using the spudger and flip it over gently towards you.
다른 한 분이 해당 안내서를 완성하였습니다.
